missing high bits of word val
Results 1 to 10 of 10
    Jan 2006
    Istanbul
    Hi there,
    What do you have in "Print2LCD" subroutine? If it is not a light speed transportation project, can you show us?
    Also,
    Why not simplify your code as below?
    FOR Tst_Array[17]=0 to 65534
        gosub Print2LCD
    NEXT Tst_Array[17]
    light speed project, that is funny! ;-)
    it just sends the array to a 2x16 lcd. hmmm, maybe i'm missing a modifier here
    Print2LCD
        FOR Ndx=0 to 18
           hserout [  Tst_Array[Ndx] ]
        NEXT Ndx
    I do not have my manual with me but what if you change:
    Tst_Array VAR word[20]
    to
    Tst_Array VAR byte[20]
    Oct 2008
    hey mackrackit & others
    i changed type to byte with the same results.
    when array is of type word, and using my debugger i see the element's value as of a word type having 16 bits. so the issue isn't with the array elements. i thinking it is the hserout performing as it is designed to do.
    what i'm seeing is the function hserout, and i assume the software version, serout, is sending values up to dec 255 then rolls back to dec 0 and starts the low bits all over again.
    going to try some things ... back soon ...
    thx
    Tst_Array[Ndx].highbyte, Tst_Array[Ndx].lowbyte ?
    compiler returns this error: This style array syntax not supported
    i'm looking at this page now for some pointers,
    http://www.picbasic.co.uk/forum/show...ht=style+array
    maybe there is a limitation on the usart for sizes >byte or there is a register config setting i've missed on this 16f88.
    i'm looking into it, back later ...
    Jan 2006
    Istanbul
    Quote Originally Posted by archendekta View Post
    Then have a word variable like
    Temp VAR WORD
    Then, modify the print routine as follow.
    Print2LCD
        FOR Ndx=0 to 18
            Temp = Tst_Array[Ndx]
            HSEROUT [Temp.LowByte,Temp.HighByte ]
        NEXT Ndx
    Last Post: - 14th June 2016, 08:55
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 9th July 2008, 00:19
  4. calculation problem
    Last Post: - 31st March 2006, 16:23
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
