missing high bits of word val
Results 1 to 10 of 10
    Default missing high bits of word val
    what i was hoping to accomplish was to put the counter val into the 17th element of the array of type word.
    but, it is only putting an 8-bit value and not a 16-bit value. i'm missing the high bits.
    i need a small push here to help me get the 16-bit val into an element of the array.
    Tst_Array  VAR word[20]
    Counter    VAR word
    FOR counter=0 to 65534
        Tst_Array[17]=counter
        gosub Print2LCD
    NEXT counter
    Jan 2006
    Istanbul
    Hi there,
    What do you have in "Print2LCD" subroutine? If it is not a light speed transportation project, can you show us?
    Also,
    Why not simplify your code as below?
    FOR Tst_Array[17]=0 to 65534
        gosub Print2LCD
    NEXT Tst_Array[17]
    light speed project, that is funny! ;-)
    it just sends the array to a 2x16 lcd. hmmm, maybe i'm missing a modifier here
    Print2LCD
        FOR Ndx=0 to 18
           hserout [  Tst_Array[Ndx] ]
        NEXT Ndx
    I do not have my manual with me but what if you change:
    to
    Tst_Array VAR byte[20]
    Oct 2008
    hey mackrackit & others
    i changed type to byte with the same results.
    when array is of type word, and using my debugger i see the element's value as of a word type having 16 bits. so the issue isn't with the array elements. i thinking it is the hserout performing as it is designed to do.
    what i'm seeing is the function hserout, and i assume the software version, serout, is sending values up to dec 255 then rolls back to dec 0 and starts the low bits all over again.
    going to try some things ... back soon ...
    thx
    Tst_Array[Ndx].highbyte, Tst_Array[Ndx].lowbyte ?
    compiler returns this error: This style array syntax not supported
    i'm looking at this page now for some pointers,
    http://www.picbasic.co.uk/forum/show...ht=style+array
    maybe there is a limitation on the usart for sizes >byte or there is a register config setting i've missed on this 16f88.
    i'm looking into it, back later ...
    Jan 2006
    Istanbul
    Quote Originally Posted by archendekta View Post
    Then have a word variable like
    Temp VAR WORD
    Then, modify the print routine as follow.
    Print2LCD
        FOR Ndx=0 to 18
            Temp = Tst_Array[Ndx]
            HSEROUT [Temp.LowByte,Temp.HighByte ]
        NEXT Ndx
    that worked sayzer. thanks.
    curious, this is the format for arrays in PBP to get word, longint values through usarts to radios?
    it's working now. now that you helped with the high-low byte. on the receiving end i'm just multiplying the highbyte by a constant and adding it to the lowbyte to get my 16bit value.
    many thanks
    Last Post: - 14th June 2016, 08:55
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 9th July 2008, 00:19
  4. calculation problem
    Last Post: - 31st March 2006, 16:23
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
