Send data PIC to PC
Results 1 to 7 of 7
    Sorry, either you are on the wrong forum or you are using the wrong basic.
    This is a Pic Basic forum.
    Dec 2009
    Default Send data PIC to PC
    The program is written in Basic PBP (mecanique) Crownhill Associates. The last part is written in VB6 in order that you observe the process of the program.
    I do not understand the problem ...
    PBP is not from Crownhill.
    DIM and DECLARE are not part of PBP.
    As far as I know.....
    Maybe PROTRON ? PROTON ?
    May 2008
    Italy
    konter you have an array of text1(n).text boxes and, with your VB code, in every box you transfer just one byte, so you must have all the boxes on the form to see something.
    Text1(1).Text = BufferIn(2)
    Text1(2).Text = BufferIn(3)
    Text1(3).Text = BufferIn(4)
    Text1(4).Text = BufferIn(5)
    Text1(5).Text = BufferIn(6)
    Text1(6).Text = BufferIn(7)
    Text1(7).Text = BufferIn(8)
    Text1(8).Text = BufferIn(9)
    It is much better with one single text box
    Dim I as Integer
    Text1.text = ""
    ' first byte is the report ID, e.g. BufferIn(0) so you start with 1
    For I=1 to 9
    Text1.text = text1.text + BufferIn(I)
    next
    In the above example you will have all the bytes nicely added to text1.text box
    Al.
    Dec 2009
    Thanks for the clarification, well I put it with intent for all who would help them to understand, because if everyone does not know how to program in VB.
    Anyway still not working,
    I put a Timer every 1ms buffer but I read nothing at all, for me the bug is in the sequence of programming the PIC, but no where with. "GoSub DoUSBOut" or "Gosub DoUSBIn" I've changed so many ways not to do.
    For the program to read the VB inside PIC and see it in textBox.
    THX
  1. Forward Serial Data from pic to pc
    By Muller in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 22:46
  2. Replies: 11
    Last Post: - 12th July 2008, 03:36
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. send serial data to PIC 16f84 ausing VB6
    By win_832001 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 22:14
  5. send and receive data using pic 16f84a
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 28th February 2006, 21:12
