Wireless serial communication question
Results 1 to 4 of 4
    Oct 2009
    Default Wireless serial communication question
    HI EVERY ONE
    i m trying to control a robotic arm with wireless serial communication between two PICs. the sender pic takes and input from a joustick potintiometers and send instructios to the receiving pic. there should be 7 bytes to send using serin command. a preamble byte $55 and 6 control bytes.
    i established the serial communication between the two pic successfully. and i tested the received data with lcd. everything works great.
    the problem is, when i wrote a PWM routine in the receiving pic, i used TMR0 interrupts. now when i try to reveive data and do PWM. the pic doesnt work.
    i tried to figure out whats wrong but i failed
    can u help me?
    here are the codes. i didnt add potentiometers reading to sender pic. i just tried to test it with numbers.
    INCLUDE "MODEDEFS.BAS"
    S1 VAR BYTE
    S3 VAR BYTE
    S4 VAR BYTE
    S6 VAR BYTE
    S7 VAR BYTE
    DC VAR BYTE
    DC1 VAR BYTE
    DC2 VAR BYTE
    CNT VAR BYTE
    S1 = 255
    S3 = 3
    S4 = 44
    S6 = 10
    S7 = 20
    DC = 77
    TRISB = 0
    PAUSE 500
    MAIN:
    PORTB.0 = 1
    PAUSE 1000
    PORTB.0 = 0
    PAUSE 1000
    PORTB.0 = 1
    PAUSE 1000
    PORTB.0 = 0
    PAUSE 1000
    DATASEND:
    SEROUT 7,T2400,[$55,S1,S3,S4,S6,S7,DC]
    PAUSEUS 2
    GOTO DATASEND
    the receiver pic code is here
    '*  Name    : W_ROB_REC.PBP                                      *
    '*  Author  : [AHMAD ABU OMAR]                                  *
    '*  Notice  : Copyright (c) 2009 [AHMAD ABU OMAR]               *
    '*  Date    : 16/12/2009                                        *
    '* DIFINTIONS
    define osc 48
    '* VARIABLES
    S1 VAR BYTE                 ' first servo motor position
    S2 VAR BYTE
    S3 VAR BYTE
    S4 VAR BYTE
    S5 VAR BYTE
    S6 VAR BYTE
    S7 VAR BYTE
    DC VAR BYTE
    DC1 VAR BYTE                ' right DC motor of mobile base
    DC2 VAR BYTE                ' left DC motor of mobile base
    OLD VAR BYTE                ' a counter variable
    dc1 = 0
    DC2 = 0
    S1 = 1
    S2 = 255
    S3 = 1
    S4 = 1
    S5 = 255
    S6 = 1
    S7 = 1
    '* MAIN PROGRAM START
    INTCON2 = $F5               ' DISBALE PORTB PULL-UPS, SET TRM0 INTERRUPT TO HIGH PERIORITY
    INTCON3 = $C0               ' DISABLE EXTERNAL INTERRUPTS PERIORITY
    RCON.7 = 0                  ' DISABLE PERIORITY LEVELS ON INTERRUPTS
    PIE1 = 0                    ' DISABLE ALL PREPHIRAL INTERRUPTS
    PIE2 = 0
    PIR1 = 0
    PIR2 = 0
    ADCON1 = 15                 ' ALL DIGITAL I/O
    TRISA = 0
    TRISB = %10000000           ' RB7 is input, used to reveive serial data
    TRISC = 0
    LATA = 0
    LATB = 0
    LATC = 0
    INTCON = %00100000          ' ENABLE TIMER0 INTERRUPTS
    T0CON = %00000101           ' SET PRESCALAR 64 FOR TMR0, APROX 5us PER INCREMENT
                                ' AND TMR0 WORKING IN 16 BIT MODE
    TMR0L = $60                 ' SET A BALANCE FOR 20ms PERIOD BEFORE INTERRUPT
    TMR0H = $F0
    ON INTERRUPT GOTO PW
    INTCON = %10100000
    T0CON.7 = 1
    MAIN:
    WHILE 1
    PAUSEUS 1
    GOSUB RECEIVE
    WEND
    '* PW: INTERRUPT SERVICE ROUTINE
    DISABLE
    PW:
    PORTB =%01111111
    OLD = 0
    TMR0L = 0
    PAUSEUS 800
    s2 = 255 - s1
    s5 = 255 - s4
    FOR OLD = 0 TO 255
    IF S1<= 0 THEN PORTB.0 = 0:S1 = 1
    IF S2<= 0 THEN PORTB.1 = 0:S2 = 1
    IF S3<= 0 THEN PORTB.2 = 0:S3 = 1
    IF S4<= 0 THEN PORTB.3 = 0:S4 = 1
    IF S5<= 0 THEN PORTB.4 = 0:S5 = 1
    IF S6<= 0 THEN PORTB.5 = 0:S6 = 1
    IF S7<= 0 THEN PORTB.6 = 0:S7 = 1
    S1 = S1 - 1
    S2 = S2 - 1
    S3 = S3 - 1
    S4 = S4 - 1
    S5 = S5 - 1
    S6 = S6 - 1
    S7 = S7 - 1
    WHILE TMR0L = OLD
    WEND
    NEXT OLD
    TMR0L =   $EF               ' SET A BALANCE FOR 18ms PERIOD BEFORE INTERRUPT
    TMR0H =   $F1
    INTCON = %10100000
    T0CON.7 = 1                 ' TIMER0 ON
    RESUME
    ENABLE
    '* SUBROUTINE RECEIVE
    RECEIVE:
    serIN PORTB.7,T2400,[$55],S1,S3,S4,S6,S7,DC
    PAUSEUS 1
    i m using PIC 16f628a on sending end and 18f2550 on the reciving end
    crystals used on both sides are 4 MHz
    Miami, Florida USA
    When I have used SEROUT or SERIN with interrupts I always use them when the interrupts are disable. Serial communications slow down your program a lot. It takes sometime time for SEROUT and SERIN to execute, so for me is better to disable the interrupts first.
    Oct 2009
    THX FOR YOUR REPLY
    robert, i m sending 7 bytes with a baud rate of 2400 . this means 240 byte per second will be recived, that is 0.24 byte per millisecond.
    since i m doing a PWM signal, the off time is 18 millisecond ( this is what i can use since it is out of ISR ).
    if i disabled the interrupt, and let serin take its time, it may take 7*(1/0.24) = 29 ms. this time i cant afford, since the PWM signal must be 50 Hz ( 20ms) and there is only 18ms free in this period.
    got what i mean?
    i ll try to recive only two bytes with ur suggestion, should i disable interrupts by writing 'disable' before serin command? and write 'enable' after it?
    i ll try what you suggeted
    Miami, Florida USA
    Yes, that is how I do it. I put the SERIN and SEROUT between the disable and enable block. Maybe somebody else here can give you more suggestions.
  1. Serial Question + General Review
    By Freman in forum General
    Last Post: - 20th June 2008, 23:27
  2. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  3. 18f4520 serial communication
    By merlinknight in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 16:30
  4. Bootloader,MCSP and Serial communication
    By surfer0815 in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2006, 11:52
  5. Replies: 8
    Last Post: - 11th November 2004, 21:08
