master HSEROUT to mixed slaves
Results 1 to 8 of 8
    Default master HSEROUT to mixed slaves
    Hi all
    This may be a simple or silly question but I am curious to know whether or not I can send data with HSEROUT and receive it on another PIC or PICS using something like SERIN,SERIN2or DEBUG and what the best choice would be.
    Up until now I have only used the same both sides, in other words if the transmitter is using HSEROUT then te receiver(s) use HSERIN
    The reason I am asking is because I would like to use hardware usart on a transmitter PIC (yes, one that supports it!) and use any other pic as a receiver (one that does not have a usart)
    Any info would be appreciated
    Kind regards
    Dennis
    Sep 2005
    Campbell, CA
    It works perfectly. You just have to make certain that you have the right state. HSEROUT "idles" high, and that generally can't be changed.
    Of course, it works in reverse as well. You can use SEROUT2 to send messages to another PIC that has a hardware receive port.
    Charles Linquist
    Default idles?
    Hi Charles
    Thanks a million for the reply
    Not quite sure what you mean by the right ildles?
    Are you referring to wait states ?
    Care to elaborate some more?
    Kind regards
    Dennis
    Sep 2005
    Campbell, CA
    Not wait states. I'm referring to the SERIN2 MODE. You have the option of TRUE and INVERTED. You will want INVERTED.
    Charles Linquist
    Default awesome!
    Thanks Charles,
    I will try it with SERIN/OUT :-)
    Keep well
    Dennis
    Quote Originally Posted by Dennis View Post
    Hi Charles
    Not quite sure what you mean by the right idles?
    Kind regards
    Dennis
    When no communication is going on, the port status is high for TRUE and Low for Inverted. The resistors should pull the port to to the appropriate idle state.
    Default aha!
    Hey Joe
    Thanks for the clarification and tip :-)
    So to confirm ..
    If mode is set TRUE a pull-up is required (any recommended value in particular?)
    and if mode is set to Inverted a pull-down resistor is needed.
    Would this prevent a possible 'floating' PIN and reduce the garbage received ?
    Kind regards
    Dennis
    Hey Joe
    So to confirm ..
    Kind regards
    Dennis
    I like something around 4 to 5 K, enough to handle it without too much power waste. I suppose that is a way of looking at it, as I see it, True switches the circuit to a low status and the pull up returns it to high and inverted switches it to high and pull down returns to a low idle state. Now I'm going to say this with <b>absolutely NO AUTHORITY</b>, As I picture it in my mind, the communication must switch between low and open impedance for true "and/or" high and open impedance for inverted, and the resistors make the circuit.
  1. I2C Slave with a PIC
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 21st August 2016, 18:44
  2. hserin and sms controller
    By xxxxxx in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 16:49
  3. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 20:12
  4. Is HSEROUT corrupting bit 7 ?????
    By Robert Wells in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2008, 17:26
  5. Controlling an 240x128 LCD Touchpanel Display
    By Vincent in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 00:36
