Darrel Taylor - Instant Interrupts-Problem 16F877A
Results 1 to 14 of 14
    Nov 2009
    London
    Question
    As long as none of the complex math or logical conditions are in the Interrupt handlers themselves, ...
    you can open the ReEnterPBP.bas file and comment the ERROR "Temp variables exceeding T4" line with a semicolon (;).
    Just to understand it correctly, I want to ask you few more questions:
    1) Can I use the following statements:
    ToggleLED1:
         goto main ' Is it ok to send the program to a label. Also no complex match or logical conditions here
    @ INT_RETURN
    'All complex code and calculations are here
    @INT_ENABLE INT_INT 'Can I place this statement here?
    @SLEEP 'Since my application is battery powered, so PIC to sleep if no command is present
    Goto main
    2) Will the next interrupt only be enabled after the code encounters @INT_ENABLE (Regardless of where I put it in the code)?
    BIG thanks for the help upto now.
    NO! That is not OK at all.
    And if all you want to do is restart the program after an interrupt, then you don't even need interrupts.
    <hr>
    Once enabled, interrupts will continue to fire.
    They do not need to be enabled again, unless manually DISABLED in your program.
    Nov 2009
    London
    Question
    .... if all you want to do is restart the program after an interrupt, then you don't even need interrupts.
    Well, I don't think I can manage without interrupts. In my code the program waits for serial data on one pin from an RF receiver. And if RI pin of my modem attached to RB0 pin goes low, the code should check any sms received as well. So, interrupt is needed.
    How I can do that-disable the interrupts (Is it by adding DISABLE before the code) ? and also can they be enabled again when needed by using @INT_ENABLE?
    ENABLE and DISABLE have no effect with DT_INTS.
    Those are only for ON INTERRUPT.
    With DT_INTS there are two commands ...
    @  INT_ENABLE  TMR1_INT
    @  INT_DISABLE  TMR1_INT
    They can be used anywhere in your program.
    Once disabled, you will not receive any interrupts from that source or peripheral until you execute another @ INT_ENABLE.
    When you INT_ENABLE, the flag is automatically cleared so you don't get an interrupt immediately if the flag was set.
    Nov 2009
    London
    Question
    Thanks for the quick relply, just some last bit of confusion left:
    1) When interrupt will happen while waiting for an RF signal - How do I send the code to go from ISR to main label?
    2) Can I disable the interrupt in the ISR? for eg:
    _ToggleLED:
    @INT_Disable
    @INT_Return ' Should I use this if I am sending the code to another label?
    Exclamation
    Like I said before.
    You should NOT jump out of an interrupt handler to the main loop.
    Nov 2009
    London
    Question
    Hello Darrel
    I am using the interrupts on 12F635 for a different program now and I am getting the following errors:
    Executing: "C:\PBP\PBPW.EXE" -ampasmwin -oq -z   -p12F635 "TxRx.bas"
    PICBASIC PRO(TM) Compiler 2.50b, (c) 1998, 2008 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Variable wsave3 position request 416 beyond RAM_END 127.
    ERROR: Variable wsave2 position request 288 beyond RAM_END 127.
    ERROR: Variable wsave1 position request 160 beyond RAM_END 127.
    ERROR: Unable to fit variable wsave
    ERROR: Unable to fit variable RS1_Save
    ERROR: Unable to fit variable RS2_SaveHalting build on first failure as requested.
    BUILD FAILED: Thu Dec 31 14:13:38 2009
    Any advise as to how to get rid of these?
    I am trying to put interrupts for getting proper timeout for Serin command, is it a good way to it? Thanks for your help.
  1. Problem displaying data from GPS module & using 16f877a
    Last Post: - 15th April 2010, 11:27
  2. 16F946 Instant Interrupts problem
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 14th April 2009, 23:20
  3. Darrel Taylor Interrupts I2C Problem
    By dcorraliza in forum mel PIC BASIC Pro
    Last Post: - 26th March 2008, 03:13
  4. 16F877A problem: "coupled" digital values
    By Lupo83 in forum General
    Last Post: - 4th December 2007, 13:46
  5. using darrel taylor's instant interrupts
    By Michael Wakileh in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 05:07
