Hi, I added rest of the statements and now I am having following errors:
Executing: "C:\PBP\PBPW.EXE" -ampasmwin -oq -z -p16F877A "GSM.bas"
PICBASIC PRO(TM) Compiler 2.50b, (c) 1998, 2008 microEngineering Labs, Inc.
All Rights Reserved.
C:\PBP\DT_INTS-14.BAS ERROR Line 14: Redefinition of VAR.
C:\PBP\DT_INTS-14.BAS ERROR Line 21: Redefinition of VAR.
C:\PBP\DT_INTS-14.BAS ERROR Line 22: Redefinition of VAR.
C:\PBP\DT_INTS-14.BAS ERROR Line 23: Redefinition of VAR.
C:\PBP\DT_INTS-14.BAS ERROR Line 26: Redefinition of VAR.
C:\PBP\DT_INTS-14.BAS ERROR Line 27: Redefinition of VAR.
C:\PBP\DT_INTS-14.BAS ERROR Line 28: Redefinition of VAR.
C:\PBP\DT_INTS-14.BAS ERROR Line 29: Redefinition of VAR.
C:\PBP\DT_INTS-14.BAS ERROR Line 30: Redefinition of VAR.
C:\PBP\REENTERPBP.BAS ERROR Line 14: Redefinition of VAR.
C:\PBP\REENTERPBP.BAS ERROR Line 20: Redefinition of VAR.
C:\PBP\REENTERPBP.BAS ERROR Line 21: Redefinition of VAR.
C:\PBP\REENTERPBP.BAS ERROR Line 22: Redefinition of VAR.
C:\PBP\REENTERPBP.BAS ERROR Line 23: Redefinition of VAR.
C:\PBP\REENTERPBP.BAS ERROR Line 24: Redefinition of VAR.
C:\PBP\REENTERPBP.BAS ERROR Line 25: Redefinition of VAR.
C:\PBP\REENTERPBP.BAS ERROR Line 26: Redefinition of VAR.
C:\PBP\REENTERPBP.BAS ERROR Line 27: Redefinition of VAR.
C:\PBP\REENTERPBP.BAS ERROR Line 28: Redefinition of VAR.
C:\PBP\REENTERPBP.BAS ERROR Line 29: Redefinition of VAR.
C:\PBP\REENTERPBP.BAS ERROR Line 30: Redefinition of VAR.
FATAL ERROR: Too many errors. (21)
Halting build on first failure as requested.
BUILD FAILED: Sun Dec 20 11:02:38 2009
Also is there any way out to get rid of 4-T error? and how it will affect my running code?
Thanks for the help in advance
