Which part?
Because 18F's oscillate just fine up to 25mhz.Also, how come my 24MHz resonators work fine with a 18F?
They Do.I thought PICs ran instructions at a quarter of the speed of the resonator
But you seem to be missing the 4xPLL part.
Are you familiar with the 4xPLL?
That is simply my suggestion.
Do your development with a crystal.
When it's all working perfectly with the crystal, test it with a resonator while varying the ambient temperature to the furthest extremes you can or really need.
If everything still works, you should be OK to uses resonators for a production run.
add: If not, you can make allowances for the deviations from "nominal".
But having timing related problems that you can't find in the program, while you're trying to program it, really sucks.
Use a crystal.
