Where to buy fast ceramic resonators
Results 1 to 14 of 14
    California, USA
    It looks like Digikey has them up to 50 MHz (40, 48, 50).
    Don't know that helps you much in the UK, but you might grab the part numbers off the ones Digikey stocks and see if you can find them closer to home.
    steve
    You aren't planning to use them on a PIC are you?
    25mhz is the highest you can go for a PIC oscillator.
    May 2007
    Actually it is 20MHz maximum for PIC16's and 40MHz for PIC18's using an oscillator in EC mode.
    For crystals/resonators the maximum is 20MHz for PIC16's and 25MHz (10MHz if PLL is enabled) for PIC18's in HS mode.
    Jun 2007
    Mansfield, UK
    Yes i was planning to use them with PICs. Im using 24MHz at the moment with PIC18Fs (i know 16Fs can only do 20). Im pretty sure 18Fs can handle upto 60MHz or atleast the ones im using can (according to the datasheet). Even 40MHz would be a help tho. Im struggling at the moment cramming all my PWM code and extras into the 6M instructions you can get with a 24MHz resonator. I will also be looking at writing the code in slightly different ways but a better resonator would help a lot.
    Ill have a look at digikey. Ive already tried my local places but it seems that nobody really uses over 16MHz. Thanks for your help
    May 2007
    Quote Originally Posted by The Master View Post
    ...Ill have a look at digikey. Ive already tried my local places but it seems that nobody really uses over 16MHz. Thanks for your help
    That's because that is the highest that is useable with any PIC18 to get the fastest clock possible - 64MHz with the newer 3.3V parts.
    Jun 2007
    Mansfield, UK
    Hmm, i think you might have to explain that one too me. Also, how come my 24MHz resonators work fine with a 18F?
    I thought PICs ran instructions at a quarter of the speed of the resonator
    Jun 2007
    Mansfield, UK
    The resonators i use dont need external capacitors (they are the 3 pin ones). Do i need to use a 2 pin one with caps?
    Edit: My circuits are already working. I just want to speed them up a bit
    Buy a 10mhz crystal with 2-22pF capacitors.
    Use the 4xPLL to get 40mhz.
    You can not run a 40mhz crystal or resonator from a PIC's oscillator.
    P.S.
    Use a crystal. Resonators have their uses, and you can figure out if it'll work in your application, after you have your application working.
  1. Detect fast movement using photodiode
    Last Post: - 22nd November 2008, 15:07
  2. Which PICs to buy ?
    By AndrewC in forum General
    Last Post: - 19th August 2008, 00:05
  3. DIY KITs - Survey
    By T.Jackson in forum Off Topic
    Last Post: - 20th July 2007, 12:34
  4. Where to buy PICs in Miami, FL, or Orlando, FL???
    By manumenzella in forum General
    Last Post: - 6th May 2007, 21:13
  5. A/D on 16F877. How fast can I go?
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 8th April 2004, 07:51
