Multi DS18b20 Code help.
Results 1 to 3 of 3
    Dec 2009
    Default Multi DS18b20 Code help.
    Hi guys.
    im stumpped.
    i currently have my pic16f628 reading from 9 DS18b20 and outputting to the pc.
    working great except its now 2000 words.
    currently i query each device in turn with its hardcoded rom id.
    like so.
        OWOUT DQ, 1, [$55,$28,$DE,$0E,$66,$02,$00,$00,$BD,$BE]
        OWIN DQ, 2, [Temp2.LOWBYTE,Temp2.HIGHBYTE]'
        TEMPnow2 = Temp2 + ofst30
        if Temp2 = 65535 then
        Temp2 = 0
        tempnow2 = 480
        hserout ["TEMP2 Raw:= ",dec4 Temp2,13]
    this works perfectly for me but thast code repeats for each DS18b20
    but i am trying to do something like the following
    i=1
        h=0
        read h, id
        while i<9
        OWOUT DQ, 1,[$55,id,$BE]
        OWIN DQ, 2, [Temps.LOWBYTE(i),Temps.LOWBYTE(i+1)]
        TEMPnows[i] = Temps[i] + ofst30
        if Temps[i] = 65535 then
        Temps[i] = 0
        tempnows[i] = 480
        hserout ["TEMP",dec i," Raw:= ",dec4 TEMPs[i],13]
        i=i+1
        h=h+8
        wend
    i have the rom id's stored in eeprom starting at 0
    the above code compiles but dont work,
    any ideas?
    thanks.
    Bombay, India
    I've made a few changes to your code. I haven't checked for correctness, but, you get the idea
    id  var byte[8]
        for i = 0 to 8
        ' read from eeprom address for the channel to ID
        for h=0 to 7
             read i*8+h, id+h
        next
        OWOUT DQ, 1,[$55,id+0,id+1,id+2,id+3,id+4,id+5,id+6,id+7,$BE]
        Temps[i] = 0
        tempnows[i] = 480
        i=i+1
        next
    Dec 2009
    Thats what i needed thanks.
    modified as below seems to be working fine.
    i had to add j and k to increment the lowbyte correctly.
    with i and i +1 it was over writing the previous bytes.
    j increments even and k increments odd prob not the best way to do it but hey it works..
    j=0
    k=1
    for i = 0 to 8
        for h=0 to 7
             read i*8+h, id[h]
        next
        OWOUT DQ, 1,[$55,id[0],id[1],id[2],id[3],id[4],id[5],id[6],id[7],$BE]
        OWIN DQ, 2, [Temps.LOWBYTE[j],Temps.LOWBYTE[k]]
        Temps[i] = 0
        tempnows[i] = 480
        j=j+2
        k=k+2
        next
  1. Reading temperature using multi DS18B20
    By KVLV in forum Code Examples
    Last Post: - 3rd November 2017, 19:48
  2. Please help with code for DS18B20
    Last Post: - 28th April 2013, 21:12
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
