Timer1 and Timer2 interrupts, Darrel Taylor
Results 1 to 3 of 3
    Oct 2009
    Austin, Texas
    Default Timer1 and Timer2 interrupts, Darrel Taylor
    I am using a PIC16F819 and I am using a Timer1 interrupt on it. I now need to add a second (Timer2) interrupt into my program. I have printed and read the following files of Darrel Taylor's to try and wrap my head around the concept of how to make this happen. I have spent two days reading a lot of posts and examples from others on this forum, but being a rookie is weighing heavy on my progress. I hope someone can shed some light on what I am not understanding on this issue.
    .bas files:
    DT_INTS-14.bas
    ReEnterPBP.bas
    Here is what I am currently attempting to do, please review and let me know what to do. I am sure mine is incorrect, but I am trying none the less. TMR2 has no TMR2L or TMR2H according to data sheet. But not sure what to do.
    OSCCON = %00000000 '32kHz
    ADCON1=7 'Digital
    TRISA = %01010100
    TRISB = %01000000
    PORTA = %00000000
    PORTB = %00000010
    TICK1 VAR BYTE
    TOCK1 VAR BYTE
    TICK2 VAR BYTE
    TOCK2 VAR BYTE
    TICK1=0:TOCK1=0:TICK2=0:TOCK2=0
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    INT_LIST macro
    INT_Handler TMR1_INT, ReloadTMR1, ASM, no
    INT_Handler TMR1_INT, _T1handler, PBP, yes
    INT_Handler TMR2_INT, ReloadTMR2, ASM, no
    INT_Handler TMR2_INT, _T2handler, PBP, yes
    INT_CREATE
    @Freq = 10
    @Prescaler = 8
    T1CON = $00
    TMR1 OFF
    T2CON = $00
    TMR2 OFF
    @ INT_ENABLE TMR1_INT
    @ INT_ENABLE TMR2_INT
    IF TOCK1 = 3 then
    PULSOUT PORTA.0,20 'RED LED BLINKS ONCE
    GOSUB StopTimer1
    IF TOCK2 = 9 then
    PULSOUT PORTA.1,20 'GREEN LED BLINKS ONCE
    GOSUB StopTimer2
    GOTO Main
    ''''''''''''''''''''TIMER INTERRUPTS''''''''''''''''''''''''''''''''''''''''
    T1handler:
    TICK1 = TICK1 + 1
    If TICK1 = 46 then
    TOCK1 = TOCK1 + 1
    TICK1 = 0
    @ INT_RETURN
    T2handler:
    TICK2 = TICK2 + 1
    If TICK2 = 46 then
    TOCK2 = TOCK2 + 1
    TICK2 = 0
    @ INT_RETURN
    ReloadInst = 8
    if ((Prescaler == 1)||(Prescaler == 2)||(Prescaler == 4)||(Prescaler == 8))
    MaxCount = 65536 + (ReloadInst / Prescaler)
    TimerReload = MaxCount - (OSC*1000000/4/Prescaler/Freq)
    if ((TimerReload < 0) || (TimerReload > (65535-ReloadInst)))
    error Invalid Timer Values - check "OSC", "Freq" and "Prescaler"
    error Invalid Prescaler
    @Timer1 = TMR1L
    Timer1 VAR WORD EXT
    TimerReload CON EXT
    TMR1ON VAR T1CON.0
    @Timer2 = TMR2L
    Timer2 VAR WORD EXT
    Timer2Reload CON EXT
    TMR2ON VAR T2CON.0
    '''''''''''''''''''''''RELOAD TIMER1''''''''''''''''''''''''''''''''''
    ReloadTMR1
    MOVE?CT 0, T1CON, TMR1ON
    MOVLW LOW(TimerReload)
    ADDWF TMR1L,F
    BTFSC STATUS,C
    INCF TMR1H,F
    MOVLW HIGH(TimerReload)
    ADDWF TMR1H,F
    MOVE?CT 1, T1CON, TMR1ON
    INT_RETURN
    '''''''''''''''''''''''RELOAD TIMER2''''''''''''''''''''''''''''''''''
    ReloadTMR2
    MOVE?CT 0, T2CON, TMR2ON
    ADDWF TMR2L,F
    BTFSC STATUS,C
    INCF TMR2H,F
    ADDWF TMR2H,F
    MOVE?CT 1, T2CON, TMR2ON
    INT_RETURN
    '''''''''''''''''''''''''''TIMER STARTS''''''''''''''''''''''''''''''
    StartTimer1:
    Timer1 = TimerReload
    TMR1ON = 1
    StartTimer2:
    Timer2 = TimerReload
    TMR2ON = 1
    '''''''''''''''''''''''''''TIMER STOPS'''''''''''''''''''''''''''''''
    StopTimer1:
    TMR1ON = 0
    StopTimer2:
    TMR2ON = 0
    Thanks in advance for the help,
    ronbo
    Timer2 is an 8-bit timer, so it doesn't have an L and H register. It's just TMR2.
    And you don't need to reload it like you do with Timer1.
    Changing the value of the PR2 register adjusts the Period, along with the pre and postscalers.
    Oct 2009
    Austin, Texas
    I see this is the case on the data sheet Darrel, and thanks for the help.....
    I see the TMR2 settings, so these will not conflict with one another or be inhibited by looping MAIN program? What else in my program is incorrect?
