DT Instant interups - interupt while executing an interupt routine question
Results 1 to 5 of 5
    Default DT Instant interups - interupt while executing an interupt routine question
    High everyone.
    I'm writing a monitoring and feedback program, a watchdog of sorts.
    it's going to be running on an 18f4550 @ 48MHz.
    the main routine is an LCD update and proberbly a bit of maths...
    However, i'll be using RX_INT along with 4 timer interupts running at diferent speeds...
    The question is, what happens if a timer interupt goes off while it's in the middle of another interupt routine say recieving usart data?
    I'm hoping it will just run the int routine for the new interupt after it finishes the curent one...
    You got it!
    That's what will happen.
    And the order they are executed will depend on the order in the INT_LIST.
    For instance ...
    With the INT_LIST below ..., INT_INT will be the first handler executed, if it's flag is set.
    Then it will do TMR0_INT next (if flagged).
    If another INT_INT happens while it's in TMR0_INT, then it will wait until TRM1_INT has also finished before it goes back around and handles INT_INT again.
            INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
            INT_Handler   TMR0_INT,  _ToggleLED2,   PBP,  yes
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
        INT_CREATE                ; Creates the interrupt processor
    If the INT_INT really can't wait for TMR1_INT then you can add another INT_INT handler in-between so that it won't have to wait.
    It still calls the same handler for both of them.
    hth,
    LOVELY!
    I was worried about 'colliding' interupts for TMR1,2 and 3 when using a single 32.7K lp xtal... would make a mess if it started executed interupt routines in the middle of an interupt routine... lol
    Thats DT and excelent work with inst ints...
    are you planning to do more on your website?
    Always glad I can help...
    Quote Originally Posted by comwarrior View Post
    Got lots of plans ... just not a whole lot of "doing" going on there.
    Darrel,
    If their is anything i can do to help then give me a shout...
  1. Timer0 Instant Interrupts Question
    By wmarchewka in forum mel PIC BASIC Pro
    Last Post: - 14th December 2009, 05:29
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT Instant Interrupt counting
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 22:47
  4. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
