Need Single wire serial LCD converter example
Results 1 to 8 of 8
    Nov 2009
    Wagoner, USA
    Default Need Single wire serial LCD converter example
    Does anyone have an example of using a pic with a single wire serial input and use like debugin then send out to a 4 bit parallel LCD.
    It's apparently harder than it sounds and a greatly kept secret.
    Ive seen 2 and 3 wire serial converters but no single wire and I haven't been able to make it work.
    May 2008
    Not certain if external links are allowed here, if not can someone remove it please
    1 wire lcd solution
    http://www.romanblack.com/shift1.htm
    He says it's all open source so I presume its ok to post.
    What I'd like is some picbasic examples of driving it (making it work) as the code he used was written in C
    Nov 2009
    Wagoner, USA
    Thanks but not exactly what I was looking for.
    Quote Originally Posted by polymer52 View Post
    Hi polymer52,
    3 wire: power, ground, data
    2 wire: data, ground
    1 wire: data . . . how does the circuit path complete? Unless you use Earth Ground, which is essentially how wireless works.
    Check out the code in post 16 of this post:
    http://www.picbasic.co.uk/forum/show...highlight=cren
    Nov 2009
    Wagoner, USA
    Well of coarse it's going to have to have a ground. I meant a single data line and ground.
    I'm using a 12f675 and I have only one pin left available. I've been sending debug info out that pin to a pc terminal but I'd rather use a LCD since I have several (parallel) lying around.
    BTW nice tag line.
    MeLabs has a simple code example showing how to make your own serial LCD here;
    http://www.melabs.com/resources/samples/x3/PBP/BPX3.BAS
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nov 2009
    Wagoner, USA
    Looks like exactly what I am looking for.
    Thanks Bruce
    Default search
    Hi there
    just search the forums for LCD BACKPACK there a plenty cool examples
    Hope that helps
    Dennis
  1. LCD serial backpacks
    By Archangel in forum Serial
    Last Post: - 30th December 2010, 05:51
  2. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 03:48
  3. one wire
    By karenhornby in forum General
    Last Post: - 18th June 2008, 21:24
  4. Serial LCD
    Last Post: - 15th November 2007, 09:31
  5. Need help with LCD number display.
