calculator-like code entry with matrix keypad and display
Results 1 to 36 of 36
    Hi Dennis.
    Well, you think simple and in most cases this is good. But not this one!
    OK. Lets take the number in your array, for example 1,2,3.
    If at the end, if you add these 3 array elements together you will get 6, or binary 6 if you want.
    What about 3,2,1? You will get the same, although is a completely different number. So you have to make calculations and multiply x100, x10 x1 and then sum up the result. Like we did at the second year of elementary school!
    I think I did gave you a sample code for this.
    Then you need some kind of LCD indexing (I covered this too, please look at your PMs).
    The 1st position of the 1st row on LCDs is $80. So if you want to display at this place use:
    LCDout $FE,$80+index,1st_character
    Then index=index+1 and your next character goes to $80:
    LCDout $FE,$80+index,2nd_character.
    Of course all the above are pure an educational example. In your code you would put some traps for the index. Also you can avoid the addition in-line the LCDout command and make the index start from $80, etc all in a loop.
    Sorry do not have the time to give you a complete working code.
    Default lost...
    Hi Ioannis
    Thanks a million for the reply,tips and guidance.
    Yes Indeed it is your sample code as well as Aratti's that prompted this thread.
    See the code snippet you sent me here (all original and intact with no changes)
    array   var byte[5]
    index   var byte
    i       var byte
    word_v  var word
    'Get keypress
    index=0
    loop:
    gosub key_read
    if mykey=32 then loop 'No key press returns 32
    array[index]=myvar
    index=index+1
    if index=5 then calculate_result
    goto loop
    caculate_result:
    word_var=0:mult=10000
    for i=index-1 to 0 step -1
        word_var=word_var*mult+array[i]
        mult=mult/10
    next i
    index=0
    goto display_result
    Ok so there were (and still are) quite a few things that didn't and don't make sense to me. And please understand I am battling to catch on to a lot of the coding tricks and reading the manual and forums and anything else that will give me some form of understanding to get functional.
    I took the code snippet and dissected it, tried my best to comment it and then add it to what I had so far.
    Then I compiled it solving each compile error as best I could (bearing in mind being a newbie it's difficult to spot common syntax errors and coding mistakes or areas that could be tweaked) and here is what I came up with:
    [code]
    'using mister_e's keypad code
    array var byte[5] 'the array set at 5
    index var byte
    i var byte
    word_var var word ' word for capturing data
    mult var byte a byte for multiplication << sould this be a word
    index=0 'sets index to 0
    loopy: 'main loop for keypress capture
    @ READKEYPAD _myvar 'read keypress variable
    LOOKUP myvar,[0,"123A456B789C*0#D"],myvar 'use lookup table to dsiplay proper keypress
    ''if mykey=32 then loop 'No key press returns 32 '<<no idea what mykey yshould be ?? a var or a word ?and why 32?
    array[index]=myvar 'build the array as the index number increases
    index=index+1 'when the code runs past here add 1 to index var
    if index=5 then calculate_result 'if the counter/index is 5 calculate result
    goto loopy 'start the loop again
    calculate_result: 'calculate results label
    word_var=0 'set word variable to 0
    mult=10000 'multiply result by 10000 to format number
    for i=index-1 to 0 step -1 'for loop begins
    word_var=word_var*mult+array[i] '
    mult=mult/10
    next i 'end of for statement
    index=0 'set index to 0
    goto display_result
    goto start
    display_result:
    lcdout word_var
    goto TX
    TX:
    hserout ["i got this string of numbers",$0d,$0a]
    hSEROUT ["Received:",STR myvar\5,$0d,$0a]
    'HSEROUT ["1st digit ", dec array(0),$0d,$0a]
    'HSEROUT ["2nd digit ", dec array(1), $0d,$0a]
    'HSEROUT ["3rd digit ", dec array(2), $0d,$0a]
    'HSEROUT ["4th digit ", dec array(3), $0d,$0a]
    'HSEROUT ["5th digit ", dec array(4), $0d,$0a]
    'HSEROUT ["5th digit ", word_var, $0d,$0a]
    goto clearkeys
    clearkeys:
    myvar = 0
    goto loopy
    [code]
    So a few observations so far ...
    The code allows for a # or * or A,B,C,D to be typed in, this messes everything up of course.
    I have no idea what the array is holding when entering the keys.How can I display the whole array on the LCD ?
    After typing in the first few characters like 00123 ended with a hash the code just does its own thing -- well at least that's how it seems.
    HSEROUT works at least because everytime I press the # key I get things in MCS serial tool window, they're just wingdings and odd characters, but at least something is happening
    Is there a way to capture each keystroke and then add convert them to binary and then add them together and then display the result as decimal ?
    I used to have an 8-way dip switch connected to the PIC and then just set the binary number up on that and it was done ! Say for example the number 123 would be as easy as flipping the switches to 1111011 and that was that.
    With a keypad I can type in the number by pressing keys 1 (wich is not 1 unless we do a look-up) same for 2 and 3 and then each number is independent and 8 bits in size.
    So in order to get the number 123 into some sort of variable I have to
    1.accept all keypresses into an array and filter out the keys *,#,A,B,C,D,and if any of these are encountered remove them from the array
    (is there a table look-up I could implement for that ?
    2.check the size of the array and if it's 3 digits then I should multiply each digit independently so 1 by 100 then 2 by 10 and 3 by 1 (or do nothing to 1)
    3.once that's done I should then be able to add them together and finally derive a total ... this total can then be checked to see if it is VALID or not. For example if it is a 3 bit number and I only want a byte then it must be less than 255 otherwise generate an overflow error on lcd.
    4.Finally I have the number , then it must either be converted to binary or decimal depending on where it should go.
    And then to top it all off the modifiers for LCDOUT and HSERIN/OUT,HSERIN2/OUT SERIN/SEROUT SERIN2/OUT and their behaviour are all slightly different.
    That said though, at least I have some code to start working with and I certainly am trying and battling along and I would really appreciate any help,tips,tricks on any of the stupid mistakes I am making or have made in the along the way to finally getting a working code/keypress/data entry system using a 4x4 or 3x3 keypad and LCD.
    I was also wondering if this hasn't come up many a time before and it seems the forums are a little sparse for something that does exaclty this unless I am searching for the wrong info ?
    Kind regards
    Dennis
    Default doing the math !
    Hi all
    I am working on the digits now, and I think I have almost got it sorted (or not!)
    I just can't see where I am going wrong and I'm sure it's the way I'm working with the array.
    To somplify things I have given the variable a set number, the number 123 as in my examples above.
    here's the code so far
    Start:
    Codex	VAR BYTE
    Temp	VAR BYTE [3]
    TempTot var byte
    Codex = 123
    Tempx var byte
    'Find character for decimal 100 column
    Tempx = Codex/100 'divide Codex by 100 'cos its the digit in 100's column
    Temp(0) = Tempx + 48 'add 48 to get ascii value
    lcdout "first " ,temp(0)
    HSEROUT ["1st digit ", Temp(0),$0d,$0a]
    'Find character for decimal 10 column
    Tempx = Codex/10 'since Codex = 123 after dividing Temp = 12
    Temp(1) = Tempx//10 'Remainder is required so with Codex = 123 the number in Temp = 2
    Temp(1) = Tempx + 48 'add 48 to get ascii value
     lcdout "second ",temp(1)
    HSEROUT ["2nd digit ", Temp(1),$0d,$0a]
    'Find character for decimal 1 column
    Tempx = Codex//10 'Get Remainder so…with Codex = 123 then Temp = 3
    Temp(2) = Tempx + 48 'add 48 to get ascii value
     lcdout "third ",temp(2)
    HSEROUT ["3rd digit ", Temp(2),$0d,$0a]
     TempTot = Temp(0)+temp(1)+Temp(2)
      hserout ["here's the binary total ",dec temptot,$0d,$0a]
     hserout ["here's the binary total ",bin temp,$0d,$0a]
     goto start
    Observations:
    The first and third digits are correct , the second is a problem (and I think it's the wrong number since it shows up as a ">" character ) so this obviously messes up the total after addition which ends up as 160 as opposed to 123 :-(
    Here is what I see in the MCS serial tool window
    1st digit 1
    2nd digit <
    3rd digit 3
    here's the binary total 160
    here's the binary total 110001
    Any help would be appreciated
    Dennis
    Last edited by Dennis; - 15th December 2009 at 05:50. Reason: Now I'm wondering if I should be multiplying and not dividing :-(
    May 2008
    Italy
    Dennis you can use the DIG command:
    Codex  var Byte
    Temp0 var Byte
    Temp1 var Byte
    Temp2 var Byte
    Codex = 123
    Temp0 = Codex DIG 0 ' set Temp0 = to digit 0 of Codex
    Temp1 = Codex DIG 1 ' set Temp1 = to digit 1 of Codex
    Temp2 = Codex DIG 2 ' set Temp2 = to digit 2 of Codex
    That all you need.
    Al.
    Hi Dennis,
    Your code looks much more difficult to me than it needs to be, you are doing a lot of "yuck" MATH, Math not my forte' , Anyway after you
    get your actual number into a variable, use the DIG function to acquire the digits.
    Digit1 var byte
    Digit2 var byte
    Digit3 var byte
    TempX var byte
    Digit1 = TempX DIG 0
    Digit2 = TempX DIG 1
    Digit3 = TempX DIG 2
    HSEROUT ["1st digit ", DEC Digit0,$0d,$0a] 'copied from your code
    HSEROUT ["2nd digit ", DEC Digit1,$0d,$0a] 'copied from your code
    HSEROUT ["3rd digit ", DEC Digit2,$0d,$0a] 'copied from your code
    I haven't looked at your code close enough to understand what the Hex 0D and Hex 0A are for, nor have I tested this code snippet, but it should give you some ideas.
    Dadgummit Al posted while I was typing! Same idea too! HiYa Al !
    Default I'm all for keeping it simple !
    Joe S and Al thanks so much for the reply !!
    And both your codes snippets work like a charm !
    I love the DIG command ...very cool !
    They certainly did simplify mine somewhat :-)
    OK so here's the deal so far.
    The HSEROUT line is working well !
    Each decimal digit is displayed correctly and in the correct order!
    So a number like 123 gets sent and displayed correctly :-)
    Now what remains is what I have been on about since the beginning of this thread and that is the following.
    I need to get each keypress stored in an array and then 'JOIN' (either by adding them or some other method ) them up into one number..that's why I went off on a tangent in the last post.
    All I would like to do is be able to send one bye or word containing the actual number keyed in.
    I would like to be able to key in the number 123 (and see it on screen) and then send it as the actual number 123 decimal or binary or hex ...just not as 3 separate bytes. Consider the same thing being done with a bank of 8 dip switches ... I set the dip switches to reflect the number 123 (bin=11110111 and hex =A3) and that's what I would read in and send.
    But this seems to be rather difficult to do using a keypad not so ?
    Again any suggestions etc would be greatly appreciated
    Kind regards
    Dennis
    California, USA
    How about something like this:
    keypressed var byte ' latest keypad entry
    mynumber var word 'your number, built up from multiple key presses
    ' each time a key is pressed, do this:
    mynumber = (mynumber * 10) + keypressed
    Maybe?
    steve
    Last edited by Byte_Butcher; - 15th December 2009 at 21:55. Reason: still learning to spell...
    Default Steve...
    Tried that ... it yeilds undesirable results .. and with each keypress a different value appears in MCS serial tool window :-(
    the numbers are 34113
    the numbers are 13500
    the numbers are 3978
    the numbers are 39830
    the numbers are 5134
    This is probably because the number is continuously multiplied each time the program loops at each keypress ... and the word value aslo can only store two bytes (16 bits)
    This is how I tried your suggestion
    'end of variables
               Pause 2000       ' Wait for LCD to startup
    Start:
      @ READKEYPAD _myvar  'read keypress variable and place in myvar
      LOOKUP myvar,[0,"123A456B789C*0#D"],myvar 'use lookup table to display proper keypress
                       lcdout myvar
                       lcdout $fe,1
    mynumber = (mynumber * 10) + myvar
    lcdout "my number ", dec mynumber
    hserout ["the numbers are " ,dec mynumber,$0d,$0a]
    The plan is along the right lines though!
    1.Check keypress to see if it's valid (0-9,A,B,C,D)
    2.Store each vaild keypress eg. 1,2,3 (number is 123) <<<<<<<<<<<THIS IS WHERE I HAVE A PROBLEM DON'T KNOW HOW TO WORK WITH THE ARRAY!
    3.Check for # character which denotes a valid input
    4.Take first character and (LSB) and multiply it by 1(byte 1)
    5.Take next character and multiply by 10 (byte 2)
    6.Take next character and multiply by 100 (byte 3)
    7. Now add them up (in this example 100+20+3 = 123)
    8.Check that number is valid ... <255 since it must be max one byte (8 bits)
    123 is valid since it's less than 255
    9.Display and send the number
    Those are the steps I need to go through :-)
    Hope that helps
    Kind regards
    Dennis
  1. a little help with keypad on 18f4520 please
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 24th November 2009, 21:38
  2. Keypad input test
    By Kalind in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 05:00
  3. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 14:16
  4. LCD display not working properly
    By dilpkan in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 08:43
  5. Keypad entry?
    By TONIGALEA in forum General
    Last Post: - 8th August 2004, 17:10
