Can we suppress leading zero's in LCDOUT?
Results 1 to 7 of 7
    Nov 2009
    Default Can we suppress leading zero's in LCDOUT?
    I'm trying to print a value in a BYTE sized VAR to a specific place on the LCD.
    (a standard 16x2, and using DT's Anypin.php)
    I need to get the number right-justified and w/o leading zero's.
    I currently have a 0-255 number comming from the ADC on AN0.
    (later I will need to do some math and expand the the result to Xnum-per-mV)
    I'm currently doing something like this:
    MYNUMBER VAR BYTE
    MYNUMBER = 0
    ADCIN 0, MYNUMBER
    LCDOUT $FE, $83, DEC MYNUMBER
    and it prints out "127 " instead of " 127" on the LCD.
    My number needs to be printed before (in front of) some text that remains on the LCD during these numeric updates, like " 127-Dingles".
    I tried DEC5 and get the digits in the right place but they have leading zero's (instead of spaces)
    Is there a way to format my number right-justified and suppress the leading zero's?
    Default this may help
    Hi there
    Just thought this may help you a little more...
    [HTML]http://www.emesystems.com/BS2math4.htm[/HTML]
    Good luck :-)
    Dennis
    Hi PICn-It,
    From your code:
    make it so
    LCDOUT $FE, $83, DEC MYNUMBER,"-Dingles"
    EDIT: I see what you are doing now, have not tried this but . . .
    LCDOUT $FE, $80, DEC MYNUMBER, $84,"Dingles"
    DEC automaticaly supresses leading zeros unless followed by a number
    Jan 2006
    Istanbul
    Quote Originally Posted by PICn-It View Post
    MYNUMBER VAR BYTE
    MYNUMBER = 0
    ADCIN 0, MYNUMBER
    At my best guess, this is what you are asking.
    You need the print always to the right.
    <font color="#000000">MYNUMBER <font color="#000080"><b>VAR BYTE
    </b></font>MYNUMBER = <font color="#FF0000">0
    </font><font color="#000080"><b>ADCIN </b></font><font color="#FF0000">0</font>, MYNUMBER
    <font color="#000080"><b>LCDOUT </b></font><font color="#FF0000">$FE</font>, <font color="#FF0000">$83
    </font><font color="#000080"><b>IF </b></font>MYNUMBER &gt; <font color="#FF0000">99 </font><font color="#000080"><b>THEN
        LCDOUT DEC3 </b></font>MYNUMBER <font color="#000080"><i>' three digits + &quot;-Dingles&quot;
        </i><b>ELSE
           IF </b></font>MYNUMBER &gt; <font color="#FF0000">9  </font><font color="#000080"><b>THEN    </b><i>' one space + two digits + &quot;-Dingles&quot;
              </i><b>LCDOUT </b></font><font color="#008000">&quot; &quot;</font>, MYNUMBER
              <font color="#000080"><b>ELSE
                 LCDOUT </b></font><font color="#008000">&quot;  &quot;</font>,<font color="#000080"><b>DEC1 </b></font>MYNUMBER   <font color="#000080"><i>' two spaces + one digit + &quot;-Dingles&quot;
           </i><b>ENDIF
    LCDOUT </b></font><font color="#008000">&quot;-Dingles&quot;
    </font>
    Nov 2009
    Quote Originally Posted by sayzer View Post
        </i><b>ELSE
           </i><b>ENDIF
    </font>
    Ahh, I see. I was hoping there would be some compiler directive/keyword/function-switch to use in PBP, something like printf in C but this is fine, whatever works ...right?.
    Since I need a posible 5-digit number perhaps turning the IF/THEN into a CASE statement would work here? something like this:
    MYNUMBER VAR BYTE
    MYNUMBER = 0
    ADCIN 0, MYNUMBER
    SELECT CASE MYNUMBER
           CASE IS > 9999
                LCDOUT $FE, $83, DEC5 MYNUMBER          ' 5 digits
           CASE IS > 999
                LCDOUT $FE, $83, " ", DEC4 MYNUMBER     ' 1 space and 4 digits
           CASE IS > 99
                LCDOUT $FE, $83, "  ", DEC3 MYNUMBER    ' 2 spaces and 3 digits
           CASE IS > 9
                LCDOUT $FE, $83, "   ", DEC2 MYNUMBER   ' 3 spaces and 2 digits
           CASE ELSE
                LCDOUT $FE, $83, "    ", DEC1 MYNUMBER  ' 4 spaces and 1 digit
    END SELECT
    Thanks for response
    Jan 2006
    Istanbul
    PICn-It,
    MYNUMBER VAR BYTE
    With that, you can get max. 255.
    Nov 2009
    PICn-It,
    MYNUMBER VAR BYTE
    Yes, good catch.
    In my code, currently I can't figure out how to steady up the 10-bit ADC reading, so I temporarily REM'd those lines:
    ADC_BITS 10
    MYNUMBER VAR WORD
    and temporarily put in:
    ADC_BITS 8
    MYNUMBER VAR BYTE
    while I work out the display screens and presentation. The CASE statement based on your IF/THEN code posted above seems to work great, thank you.
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  2. Suppress leading zeros
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 24th June 2008, 22:45
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 03:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
