How do I add a decimal point?
Results 1 to 5 of 5
    Nov 2009
    Wagoner, USA
    That worked great..Thank you.
    And for debug I used:
    DEBUG 1," Channel 0: ",DEC(ad0/10),".",DEC(ad0//10),10,13
    You can have a problem with leading zeros in the part after the decimal point, not sure if it effects PBP but it certainly effects picaxe basic.
    Example
    I want to display 102 as decimal with the . between 1 and 0
    1.02
    If you use the method suggested I expect the display will actually show
    1.2 and not 1.02
    It probably works correctly as long there is a number other than 0 present.
    i.e.
    122 would work and display 1.22
    102 would not and would display 1.2 not 1.02.
    Anyone care to comment.
    Here is some picaxe code I use which can probably be adapted for this issue in PBP
    VarC = Soc / 100			;Get first part of value (Before decimal point)
    VarA = Soc // 100			;Get second part of value (After decimal point)
    serout Video,BaudT9600,(27,83,0,5,"Soc ",#VarC,".")	;Video Display
    if VarA < 10 then			;If Leading zero reqd in display due to Value <10 then
    serout Video,BaudT9600,("0",#VarA," % ")	;Video Display
    serout Video,BaudT9600,(#VarA," % ")	;Video Display
    YUP, I will comment..
    The sample code Charles gave will return 10.2 if 102 is entered.
    This will take the last two numbers, even if the numbers are both zero and put them behind the decimal point.
    HSEROUT [DEC X/100,".",DEC2 X//100]
  1. MAX7219 Helping Hand Please
    By isaac in forum mel PIC BASIC Pro
    Last Post: - 14th February 2014, 16:07
  2. Adding Decimal Point
    By markscotford in forum mel PIC BASIC Pro
    Last Post: - 24th August 2009, 17:12
  3. Decimal point with serout?
    By Kman in forum mel PIC BASIC Pro
    Last Post: - 7th July 2007, 15:33
  4. hex ascii help please
    By ffr58kk90 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2006, 22:09
  5. 16bit variable and degrees conversion
    Last Post: - 2nd May 2005, 18:27
