16 bit PWM using CCP1 - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 61 of 61
  1. #41
    Jun 2009
    Sc*nthorpe, UK
    Default Re: 16 bit PWM using CCP1
    your version cannot work since CCP1CON and CCPR1H are not in bank 0
    and yes the code you marked red serves no purpose in the given example
    My point was that the code in red stopped it working and I could not work out why it was there.
  2. #42
    the code in red just wastes time ,it's not what stopped the program from working . the problem is the changing sfr's in the wrong bank.
  3. #43
    Jun 2009
    Sc*nthorpe, UK
    It did stop it working on my 18F452 though.
  4. #44
    bsf INTCON,7 ;GIE = 1
    bsf INTCON,6 ;PEIE = 1 Enable peripheral interrupts
    bsf PIE1,0 ; TMR1IE= 1 Enable TMR1
    intcon bits 6 and 7 should already be set , setting them again should do no harm
    pie1.0 is also set , setting it again can't hurt
    it just wastes 12 cpu cycles
    the problem lies elsewhere, PWM_VAL must be > 30 ,values from 0-29 wont work could that have happened
  5. #45
    Jun 2009
    Sc*nthorpe, UK
    That is exactly what I thought and could not find anything to indicate otherwise in the datasheet.
    No I started PWM_VAL for zero and incremented up in steps of 1 and it worked all the way rolling over and starting from 0. If 0-29 does not work I could not detect it with my voltmeter.
  6. #46
    just tried your "red" code in the isr on a pic18f45k20
    you are right
    these two lines lock it up. can't see why yet
    it looked harmless but its not ,its much worse than useless
  7. #47
    N
    I'm using a cro those <30ish pwm's cause the output pin to be permanently high when you expect a very small pw , in real life that could be nasty
    try a loop range yourself of 0 to say 28
  8. #48
    Jun 2009
    Sc*nthorpe, UK
    The point of coming here is to learn and I am now comparing the architecture of the 18F452 and the 16F1827. They are completely different, not surprise there.
    I have found the sfrs are in bank 5 on the 16F1827 but I have no idea how to use this information.
  9. #49
    Jun 2009
    Sc*nthorpe, UK
    N
    Just tried it no problem 0 gave 0 volts 9 gave 3 mV.
  10. #50
    CALLS TO ASM always set bank 0
    pbp has a macro you can use "chk?rp sfr" it will ckeck that the appropriate bank is set (see status or bank sfr)
    the mpasm assembler can also do a " BANKSEL SFR"
    BEFORE YOU RETURN T0 PBP YOU MUST SET BANK BACK TO BANK 0
  11. #51
    not on a cro
    using a main loop like this
    MAIN:
    PWM_VAL = PWM_VAL+1
    PAUSE 500
    if pwm_val > 29 then pwm_val=0
    toggle portd.1
    Goto MAIN
  12. #52
    Jun 2009
    Sc*nthorpe, UK
    not on a cro
    What is a cro?
  13. #53
    oscilloscope
    depending on your age , in the old days a cathode ray oscilloscope, cro for short
  14. #54
    Jun 2009
    Sc*nthorpe, UK
    N
    I will take your word for it as I have no instrument that will replicate your results, and as I have found in the past just because I can not see it does not mean it is not there.
  15. #55
    the 30 figure came from the pic16f1825 using dt_ints14
    for a pic18f45k20 the figure is 25 using dt_ints18
    for a pic18f45k20 using DEFINE INTHAND the figure is 11
    seems dt_ints introduces more latency
    point is 0 is not off and pwm < latency is not a small pw
  16. #56
    Nov 2009
    Richard,
    Thanks for your reply.
    Yes, you're right. 103 error occurs after compiling. Banksel command is used, will you?
    Talat
  17. #57
    Nov 2009
    Yes, you're right.
    My first version was like you, did not work. To better understand the problem I have added including red lines.
    I tried again and the result is the same version. In the start-up process produces two pulses and then stops.
  18. #58
    Nov 2009
    I installed the PBP trial version 3.0.7 to try. Nothing's changed. Error 113 continues (Post 56, I wrote 103, it's wrong)
Size:  60.1 KBName:  16b.png
  19. #59
    Check your spelling of CCPR1H and CCPR1L.
    Nov 2009
    Henrik, congratulations for being careful, thank you.
    This is a completely copy-paste disaster
    Talat
  21. #61
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by talatsahim View Post
    Talat
    That error comes from post #35 and #37 is there anyway these posts can be corrected?
    Last Post: - 14th June 2016, 07:55
  2. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 22:18
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
  4. How to tell which PICs can handle 16 bit variables?
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 08:44
    Last Post: - 6th March 2005, 01:07
