PC Serial comms
Results 1 to 8 of 8
Thread: PC Serial comms
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default PC Serial comms
    I'm using a VDrive2 module that communicates by RS232 at 9600 Baud. The problem is:
    1. Using PBP code on a PIC16F877A connected to the VDrive2 works properly. The VDrive module responds to commands and returns data correctly.
    2. Connecting the VDrive module to the PC by a RS232 converter chip works OK - but only for the first command, after that the VDrive2 will only send 'Bad Command.' Cycle the power and again it accepts one command, returns the correct data but won't respond to a second command, jut 'Bad Command' again.
    I'm not using RTS or CTS on either set-up.
    What's different between the PIC RS232 and the Max chip to the PC?
    Regards Bill Legge
    Do you have CTS , PIN 10 I think, connected to the zero rail?
    Nov 2007
    Default Pc rs232
    Sorry - I guess I am using CTS - it is connected to ground!
    Regards Bill Legge
    The PIC does TTL and the MAX does RS232.
    What is the command you are sending that causes trouble or does it matter which one?
    Nov 2007
    All of the Vdrive2 commands work but once only and then the power needs cycling.
    I think it's some CTR/RTS thing?
    Regards Bill Legge
    Nov 2007
    Default PC Comms
    I've just tried a different terminal program - and it all works OK.
    The terminal program incorporated in PBP won't work?
    Regards Bill Legge
  1. Serial Comms through TX/RX pair jumbled
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 28th July 2009, 22:04
  2. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  3. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 23:35
  4. Replies: 2
    Last Post: - 23rd July 2006, 09:16
  5. Interrupt and Serial communication to PC.
    By obaskirt in forum mel PIC BASIC
    Last Post: - 17th June 2005, 21:01
