brushless speed control
Results 1 to 9 of 9
    Puerto Rico
    Talking
    Thanks for help
    My Hobbies is PicBasic PRO
    Puerto Rico
    Unhappy
    no work PULSOUT PORTB.2,255 i use all number from 0 to 1000 and the speed control no start the motor
    Thunderbird 18 from castlecreations
    Angry
    Quote Originally Posted by jetpr View Post
    May be simply a look to the user manual ??? ...
    http://www.castlecreations.com/suppo...user-guide.pdf
    and another look to general R/C signals values ...
    From the time you " play " with those toys you should know all that.
    NOW ... not a PbP issue at all !!! ... for sure
    Puerto Rico
    Post
    how i made the picbasic pro to do this
    The ESC requires a 50Hz carrier signal between 1 millisecond and 2 milliseconds to operate. 1ms is zero throttle and 2ms is full throttle. You will not need to program the speed controller unless your robot requires a different voltage cutoff, brake disabled, or motor rotation direction
    malc-c's Avatar
    malc-c Guest
    Which is a standard R/C PPM signal. 1-2ms pulse repeated every 20ms
  1. Replies: 14
    Last Post: - 26th September 2007, 06:41
  2. Speed Control (help Idea)
    By jetpr in forum General
    Last Post: - 1st November 2005, 02:51
  3. Replies: 9
    Last Post: - 30th August 2005, 07:33
  4. speed control
    By Kees Reedijk in forum mel PIC BASIC Pro
    Last Post: - 1st April 2005, 00:07
  5. Electronic speed control
    By actionplus in forum Schematics
    Last Post: - 21st June 2004, 20:01
