brushless speed control
Results 1 to 9 of 9
    Sep 2005
    Campbell, CA
    I assume that your motor already has commutation circuitry. In that case, you need to build a 'buck' converter and use a PIC with a hardware PWM port to drive the FET. If the motor has a tachometer output, you will need to drive the high side (using a P-channel FET), because most tachometers are ground-referenced.
    Charles Linquist
    Puerto Rico
    Post
    no am using a castle brushless speed contol i need to send pulse to the r/c connector to made run the motor like connect to a r/c radio
    My Hobbies is PicBasic PRO
    Wink How's your turbine ???
    Hi, JetPr
    Long time we didn't hear from you ...
    So, do not loose our good ol' habits ...
    I understand from your post you have a brushless ESC and you need a servo signal generator to drive it without using a R/C set ???
    is it true ??? ...
    sooo ...
    http://www.rcgroups.com/forums/showthread.php?t=1151221
    http://www.picbasic.co.uk/forum/show...10&postcount=5
    or simply GOOGLE " Servo driver " ... TONS of answers ( W/ 555, 4011, 324 ... Pics, Atmels, Freescale ... )
    and from a computer
    http://www.rentron.com/PICX5.htm
    Puerto Rico
    Talking
    Thanks for help
    Puerto Rico
    Unhappy
    no work PULSOUT PORTB.2,255 i use all number from 0 to 1000 and the speed control no start the motor
    Thunderbird 18 from castlecreations
    Angry
    Quote Originally Posted by jetpr View Post
    May be simply a look to the user manual ??? ...
    http://www.castlecreations.com/suppo...user-guide.pdf
    and another look to general R/C signals values ...
    From the time you " play " with those toys you should know all that.
    NOW ... not a PbP issue at all !!! ... for sure
    Puerto Rico
    Post
    how i made the picbasic pro to do this
    The ESC requires a 50Hz carrier signal between 1 millisecond and 2 milliseconds to operate. 1ms is zero throttle and 2ms is full throttle. You will not need to program the speed controller unless your robot requires a different voltage cutoff, brake disabled, or motor rotation direction
  1. Replies: 14
    Last Post: - 26th September 2007, 06:41
  2. Speed Control (help Idea)
    By jetpr in forum General
    Last Post: - 1st November 2005, 02:51
  3. Replies: 9
    Last Post: - 30th August 2005, 07:33
  4. speed control
    By Kees Reedijk in forum mel PIC BASIC Pro
    Last Post: - 1st April 2005, 00:07
  5. Electronic speed control
    By actionplus in forum Schematics
    Last Post: - 21st June 2004, 20:01
