ELAPSED.PBP modification question
Results 1 to 5 of 5
    Default ELAPSED.PBP modification question
    Can I change the interrupt hertz from 100 to 1000 and then have 0.001 resolution?
    You can.
    You would need to change the TimerConst so that it interrupts at 1khz.
    You can use mister-e's calculator for that.
    Change the Ticks variable to a WORD.
    Then in the ClockCount routine, change to this ...
        Ticks = Ticks + 1
        if Ticks = 1000 then
           Ticks = 0
           Seconds = Seconds + 1
    ; etc.
    Happy Holiday's,
    Great. I downloaded the calculator and am using the 'timer helper' module. I am using a 20 Mhz OSC. I am not too sure as to what I need for a reload number. I enter in 1 Khz for the interrupt frequency. Using 10 for the reload number I get 60546 for the preload result. Hex is then ec82. If this correct? I am going to reverse engineer using your numbers for 0.01 resolution to see if its right. I am at the in-laws without my scope so I can't check this today.
    Thanks for the help
    Toby
    I better clarify, I am using Elapsed-18.pbp if it matters.
    Very good.
    Elapsed-18 uses an 8-instruction reload.
    So, 60544 (EC80) should be a little more accurate.
    Can't help with the in-laws ... Sorry.
  1. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  2. FREQOUT - PWM question
    By Etcho in forum mel PIC BASIC Pro
    Last Post: - 26th February 2007, 00:51
  3. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
  4. Question for a math guru
    Last Post: - 22nd November 2006, 10:45
  5. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
