Break up your delays into shorter PAUSE times so it can react to each interrupt faster, and
don't mess with INTCON.7 when using ON INTERRUPT.
PBP places a RETURN at location 4 (hardware interrupt vector), so INTCON.7 gets left clear
and this lets PBP know an interrupt needs to be serviced.
INTCON.7 is automatically set on return from your interrupt handler. If you set INTCON.7 in
your code, after ON INTERRUPT is used, PBP assumes the interrupt has already been
serviced.
See if this helps;
Code:DEFINE NO_CLRWDT 1 DEFINE OSC 4 Include "modedefs.bas" led VAR gpio.1 i VAR BYTE X VAR WORD @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_ON & _BOD_ON & _CPD_ON & _IESO_OFF & _FCMEN_ON & _WUREN_OFF main: ' Initialize the processor TRISIO = %111000 GPIO = 0 CMCON0 = 7 INTCON=128 OPTION_REG =%10000111 ' RAPU = off, PS 1:256 to TMR0 (overflows in 256*256*1uS) 65.536 mS pcon.5=0 pie1=0 t1con.0=0 i=0 ON INTERRUPT GOTO start pause 50 check: if gpio.5=1 then ' Takes GP0 high BUT not low toggle gpio.0 'pause 300 ' TMR0 will overflow long before this PAUSE is finished FOR X = 1 TO 300 ' 300mS PAUSE in 1mS increments PAUSE 1 NEXT X while gpio.5 pause 1 wend endif if gpio.4=1 then ' Independently working fine BUT also takes low gp.0 if it's high only toggle gpio.1 'pause 300 ' TMR0 will overflow long before this PAUSE is finished FOR X = 1 TO 300 ' 300mS PAUSE in 1mS increments PAUSE 1 NEXT X while gpio.4 pause 1 wend endif if gpio.3=1 then gpio.2=1 'pause 100 ' TMR0 will overflow long before this PAUSE is finished FOR X = 1 TO 100 ' 100mS PAUSE in 1mS increments PAUSE 1 NEXT X while gpio.3 pause 1 wend TMR0=0 INTCON.5 = 1 ' enable TMR0 overflow interrupt endif goto check disable start: i=i+1 INTCON.2=0 ' clear TMR0 overflow interrupt flag bit if i=77 then gpio.2=0 i=0 ' INTCON=128 ' INTCON.7 gets set on return from here endif resume
