10W/20W High Power White LED
Results 1 to 11 of 11
    Hello Guys,
    Thank you very much for your answers! I forgot to mention which LEDs I'm talking about. These are the ones:
    http://cgi.ebay.com/1-PC-10W-WATT-ST...item27ada81b9d
    http://cgi.ebay.com/20W-White-Led-10...item27ad5b8aec
    I'm only going to use them for about 3 hours a week, so I don't need something expensive.
    Thanks!
    Daniel.
    Hey Guys and Melanie,
    Today, I got the 10W white LEDs I was talking about...
    These things are too bright!!! And, also, too hot!!! The diameter is 22.5mm and they are huge!!!
    I'll put some pictures soon, when I have the circuit for them (3S LiPo + heatsink + cooler) up and running...
    Thanks!
    Daniel.
    Miami, Florida USA
    Yes, they are bright. I bought a few 1.5W white power LEDs a few months ago for one of my projects and I was really surprised to see how bright they are.
    They are also hot. You need to design your PCB board with some means to disipate the heat (heat sinks).
    Hey Guys,
    Which transistor or mosfet can I use to control (on/off/pwm) these LEDs?
    They need 12v and 1A, if possible, I don't want to add a heatsink to the transistor.
    Thanks!
    Daniel.
    California, USA
    Hmmm... welll.... There's probably about a million devices that MIGHT be suitable.
    What package styles are you willing to consider will narrow it somewhat. What's readily available to you might narrow it a lot more.
    Look for an N-channel MOSFET that has a good low RDS(on) that's specified at a LOW gate voltage. (Vgs)
    A PIC running on 5 volts may not put out much more than 4 volts on it's I/O pin, so it's important that you can turn the MOSFET on good and hard with a Vgs less than 4 volts.
    It doesn't do any good to have a small RDS(on) if it takes 8 volts of gate drive to get it....
    I use a lot of these but they are in an SOT223 package. They will handle over an amp easily if they are on a circuit board that has adequate pad area under the FET's
    http://www.fairchildsemi.com/ds/FD/FDT439N.pdf
    But you probably don't want SMD?
    A TO-220 or similar package would easily dissipate enough heat for what you want without further heatsinking.
    steve
    Look for the BUK9575 from NXP. Logic driven MosFET.
    http://www.nxp.com/documents/data_sh..._9675-100A.pdf
    alicesmile's Avatar
    alicesmile Guest
    arrel produced the 1st version of the PID code to drive just one channel. I then compiled and ran it to see how it performed. Over the course of several evenings I managed to get the values tweaked enough to maintain a stable temperature that would drift no more than 0.5 a degree in the course of the evening.
    Armed with the feedback, DT then went on to work on multiple channel PID loops, and after a few weeks of frantic PM's between him and Henrik came back with some further code for me to test and try. The result was that after some further tweaking at my end, we managed to have 4 independent channels all running at the same time and in the test rig, maintaining a constant temperature.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  4. LCD will not start
  5. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
