If you can program the 877 with your device programmer, and your code runs as expected, I doubt your controller is bad.
Are you using DEFINE LOADER_USED 1?
Are you using DEFINE OSC ? & a crystal frequency that matches the loader firmware you program into the target?
Have you checked/verified the comm port the loader software is set to use?
Do you have the MCS loader software set for Auto Detect under Options >> Baud Rate?
