how synchronize with rfid reader
Results 1 to 10 of 10
    Apr 2009
    Default how synchronize with rfid reader
    i have rfid reader module sending serial data 8n1 9600 baud at TTL format
    and transmits 7 byte with one second cycle
    i used serin2 and serin commads and received data and displayed them on display without synchronization data is changing and floats even it reads same tag
    at proteus a make coomunication by simulating rfid reader as a pic628 sending 7 byte data like reader and
    i will use hserin command
    how can i synchronize pic877a with rfid reader which command must be used
    at this kind of communication
    I must be silly, sort of, but I read your post again and again, I try to understand, I just can't
    We will need more information, Is this more a ISIS problem or Code problem here?
    Apr 2009
    not isis problem
    it is code problem
    how can i communicate pic16f877 with rfid reader module which sending data 8n1 9600 baud at ttl format
    which command of picbasic must be used to receive this kind of data ?
    For the receiver
    SERIN/DEBUGIN/SERIN2/HSERIN would work. Also possible and recommended to use USART interrupt to allow to do something else while there's no incoming data.
    For the transmitter
    SEROUT/DEBUG/SEROUT2/HSEROUT
    Apr 2009
    i can receive data and show them on display
    but i cant receive correct data
    (i must receive $00,$05,$01,$1A,$01,$2F,$55)
    and codes on the display changing and floating even i read same rfid tag
    i know these serial commands i use them but i dont know how to organize them to receive bytes 8n1 9600 at ttl format
    HSERIN [HEX2 VAR1, HEX2 VAR2, and so on]
  1. Parallax RFID Reader code example
    By dan-tron in forum Code Examples
    Last Post: - 19th April 2013, 23:16
  2. Replies: 3
    Last Post: - 12th March 2008, 06:33
  3. parallax rfid reader module interface with PC
    By jonil22 in forum Off Topic
    Last Post: - 3rd February 2008, 07:54
  4. Parallx rfid reader module interface with PC
    By jonil22 in forum mel PIC BASIC Pro
    Last Post: - 31st January 2008, 09:50
  5. Serial interface with RFID reader
    By brid0030 in forum Serial
    Last Post: - 23rd January 2007, 07:23
