Small great problem
Results 1 to 5 of 5
    Jul 2005
    Ferrara - Italy
    Unhappy Small great problem
    Hi to everybody!
    I would like to realize a device that converses with a PC through the door PS2, using a PIC 16F877A.
    The device should send to the PC, the letter "r" if the key P1 is pressed on RD0, the letter "c" if the key P2 is pressed on RD1 and the letter "s" if the key P3 is pressed on RD2.
    I have realized the following code, but it doesn't work... where is the error?
    Thanks everybody!
    Best regards!
    @ DEVICE HS_OSC
    @ DEVICE pic16F877A
    DEFINE OSC 20
    DEFINE SHIFT_PAUSEUS 15
    INCLUDE "modedefs.bas"
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3
    DEFINE LCD_LINES 2
    symbol P1 = PORTD.2
    SYMBOL P2 = PORTD.1
    SYMBOL P3 = PORTD.0
    symbol LED = PORTA.0
    Symbol dat = PORTC.0
    symbol clk = PORTC.1
    i var byte
    Value Var word
    clear
    ADCON1 = 7
    dat = 1
    clk = 1
    lcdout $fe,1,"** Test PS2 **"
    LCDOUT $fe,$c0,"Value: ",Value," "
    FOR i = 0 TO 5
    TOGGLE LED
    PAUSE 200
    NEXT i
    GOTO Main
    if P1 = 0 THEN
    Dato = $73
    lcdout $fe,$c0,"Key: ",Value," "
    Pause 50
    GOSUB TX
    if P2 = 0 then
    Dato = $63
    Pause 50
    GOSUB TX
    if P3 = 0 then
    Dato = $72
    Pause 50
    GOSUB TX
    goto Main
    TX:
    shiftout dat,clk,0,[Value\11]
    pause 50
    May 2008
    Italy
    Variable Value is not loaded with the character that you load into byte Dato, if you want it to be displayed than either you print also variable Dato or as in the example below you transfer Dato into Value.
    correct your ascii code for the letters c;r and s
    '$63 = c
    '$72 = r
    '$73 = s
    if P1 = 0 THEN
    'Dato = $73 '
    Dato = $72
    Value=Dato
    Pause 50
    GOSUB TX
    Al.
    Jul 2005
    Ferrara - Italy
    Red face
    Quote Originally Posted by aratti View Post
    '$63 = c
    '$72 = r
    '$73 = s
    if P1 = 0 THEN
    'Dato = $73 '
    Dato = $72
    Value=Dato
    Pause 50
    GOSUB TX
    Al.
    Thanks Aratti! Thanks very much!
    I have effected the changes from you signalled and in effects we are now all some right ... It's still me impossible to send the data on the PS/2. Is it possible that the error is in the command SHIFTOUT?
    Thanks very very muche for your irreplaceable help!
    May 2008
    Italy
    .... Is it possible that the error is in the command SHIFTOUT?
    I think you have spotted the problem. Read the thread @ the given link, it will help you in understanding the ps2 protocol.
    http://www.picbasic.co.uk/forum/show...=communication
    Al.
    Jul 2005
    Ferrara - Italy
    Al.
    Thank you very much!
  1. USART Problem , but don't know where, in pc? or in PIC?
  2. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 22:04
  3. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 22:39
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. HSEROUT Problem
    By Keith in forum General
    Last Post: - 25th June 2005, 16:09
