Problems setting INTCONx registers in 18F4550
Results 1 to 3 of 3
    Mar 2009
    Colorado
    Default Problems setting INTCONx registers in 18F4550
    I am coding for a PIC 18F4550 with PBP 2.6. I need to set some of the bits in the INCON2, INCON3 and RCON registers and keep getting syntax errors at compile time for the following statements. As far as I can see in the Datasheet and the PBP manual these are correct syntax yet the errors. Can anyone tell me what is wrong with these?
    ' Interrupts Settings
        RCON = %10000000      ' Set Interrupt Priority Enable bit (Bit7=IPEN)
                              ' to enable priority levels on interrupts
        INTCON.7 = 1          ' Set Global Interrupt Enable bit
        INTCON2.7 = 1         ' Enable PORTB Pull-ups (Bit7-high), set INT2 for
                              ' falling edge (Bit4-low) on RTC's interrupt.
        INTCON3 = %10010000   ' Set INT2 high priority (Bit7-high), enable INT2
                              ' (Bit4-high)
        RTC_INT_FLG  VAR INTCON3.1 'Alias for RB4 INTA interrupt from RTC
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default Compile errors
    I hesitate to say this as I guess you must be an experienced PBP programmer - have you selected the chip type as 18F4550 in the 'chip select' box?
    Regards Bill legge
    Mar 2009
    Colorado
    Talking Duhh...that was it...senior moment!
    Quote Originally Posted by Bill Legge View Post
    Thanks, Bill. . Even experienced programmers have their senior moments. I should have looked at the device setting all along
  1. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 15:01
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
