POOKECODE and PEEKCODE
Results 1 to 15 of 15
    Apr 2008
    Hello Alain,
    thanks, both EEPROM and DATA, WRITE and READ are work well
    regards,
    Apr 2008
    Default pokcode redo
    hi ,can someone help to see where is problemes are
    the output is only the first byte of data stored in a table
    pic16f877A
    ADCON0 = 0
    ADCON1 = 7
    define osc 20
    trisB = 0 ' SET PORTB AS OUTPUT
    PORTB = 0 ; SET PORTB t and C to 0
    trisc = 0
    portc = 0
    trisd = 0 ; 2 pins of this port is for reset and clock
    erasecode $500 ; erase code space @$500 (page 0)
    B0 var word
    StrAddr var word
    F0 var byte
    E0 var byte
    k var byte
    LOOP ; this loop display the value stored in the flash
    b0 = 0 ; initial value
    FOR StrAddr = 500 to 505 step 2 ; read a word
    call display
    NEXT StrAddr
    goto loop
    DISPLAY:
    Peekcode StrAddr, b0 ; fetch a value from table
    f0 = b0.lowbyte
    e0 = b0.highbyte
    call output1
    output1:
    for k = 0 to 30 ; output 2 ports of B and C
    call reset
    portb = f0
    portc = e0
    call delay
    next k
    RESET: PORTd.2 = 1 ;RESET 4017 pin 16-PIC
    @NOP
    PORTd.2 = 0
    DELAY:
    pause 1 ;
    portb = 0 ; reset portb , c
    portc = 0
    portd.3 = 1 ; clock the 4017 pin17-PIC
    @nop
    portd.3 = 0
    pokecode @$500, $2a,$55 ,$55, $2a ,$55 ,$2a ; store data in flash mem
    thnaks for all reply,
