i2c with a dac
Results 1 to 12 of 12
Thread: i2c with a dac
    fabritio's Avatar
    fabritio Guest
    Default i2c with a dac
    Hello,
    I am quite new in picbasic programming.
    I am trying to figure out if it's possible to send bits to a dac (tc1321) form a pic16f876.
    I want to send a 10bit serial word to the device.
    I wrote this program:
    SDA var byte
    SCL var byte
    ADDR var byte
    VAL var word
    i var word
    TRISB.4 = 1 ' Pin B4ingresso
    TRISC = 0 ' Porta C uscita
    SDA = 12 ' Imposto l'uscita SDA sul pin C4
    SCL = 11 ' Imposto l'uscita SCL sul pin C3
    ADDR = %10010000 ' Indirizzo del TC1321
    if PORTB.4 then
    goto inizia
    inizia:
    val = %0000000000
    for i=0 to 14
    i2cwrite sda,scl,addr,[val]
    val = val + %1000000
    next
    val = %1111111111
    while PORTB.4 = 0
    wend
    goto inizia
    Do you think it's right or I've done GREAT errors?
    Thank you very much!!
    Fabrizio
    fabritio's Avatar
    fabritio Guest
    Originally posted by Acetronics
    I suppose it might have been this
    for i=0 to 14
    val = val + %0000001
    instead of that
    for i=0 to 14
    or there's no need for a DAC.
    I only meant to do a conversion from 0 to 1024 in 16 steps, so I add 64 for every step (%1000000).
    Thank you for the answer however...
    Question
    Hi
    I undertand ...
    But, you're sending a 16 bits word for 10 needed bits ...
    is that a problem with the DAC ???
    fabritio's Avatar
    fabritio Guest
    So, how can I define that I am sending only 10 bits?
    fabritio's Avatar
    fabritio Guest
    Is there a configuration of the SSP registers that I have to do first?
    i2cwrite sda,scl,addr,[val\10]
    fabritio's Avatar
    fabritio Guest
    Thank you,
    i am still wondering about the ssp registers configurations....
    Question
    Did you had a look at table 4-4 page 10 from the TC Datasheet ???
    Seems that the 6 lower data bits must be 0, and 16 bits to be sent.
    so your example gives the 2 to 16 lower values ( less than 4% of full output ... )
    that at a very high speed , as there is no PAUSE between each FOR-NEXT ... and then jumps and stops to the max value.
    output seems not to be clearly visible ... even on a good scope !
    Bongo's Avatar
    Bongo Guest
    Default Tc1321 Sample Code Please!
    Please send me working Basic code for TC1321 ...
    Feb 2004
    Germany
    Bongo,
    great start on this forum!
    here is your welcome gift
    regards
    Ralph
    scholar's Avatar
    scholar Guest
    @ device hs_osc
    define osc 4
    Ctrl con %10010000
    CPIN var portb.1
    DPIN var portb.0
    trisa=0
    porta=255
    porta=0
    pause 1000' Pause 50ms for MC23016 to start-up
    i2cwrite DPIN, CPIN, Ctrl,%00000000,%10000000,%00000000 '512*Vref/1024
    pause 2000
    i2cwrite DPIN, CPIN, Ctrl,%00000000,%00000000,%00000000
    pause 2000
    with this code i able to generate analog voltage at the output. But funny thing is i only able to generate the first value (512*Vref/1024) but no respond after 2s. It suppose to change to 0V after 2s.
  1. I2C Master/Slave 16F88/16F767 working code
    By DanPBP in forum Code Examples
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    By Michael Wakileh in forum Code Examples
    Last Post: - 16th June 2009, 22:07
  3. Another I2C Slave Routine Problem
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 06:50
  4. I2C Master Slave issues.
    By cpayne in forum mel PIC BASIC Pro
    Last Post: - 29th March 2008, 20:33
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
