Ir problem sending data
Results 1 to 1 of 1
    May 2009
    Default Ir problem sending data
    HELLO . IM USING PIC16F628 TO SENT CHARACTERS TO PIC16F84 VIA IR , BUT WHEN I SEND 12 I GET 03 OR SOME STRANGE NUMBERS I TRYED TO CHANGE BAUDS AND Initialize hardware PWM , RUNING ON 4MHZ OSC , NEED HELP THIS IS MY CODE
    TRNASMITTER IR ,PIC16F628A
        @ DEVICE INTRC_OSC_NOCLKOUT, LVP_OFF, MCLR_OFF, WDT_OFF
        DEFINE INT_OSC 4
        B0        VAR byte
        Baud         CON 16780
        'Initialize hardware PWM - IRLED 40KHz drive
        PORTB     = %00000000
        TRISB     = %00000000
        CCPR1L    = 12         ' Set PWM Duty-Cycle to 50%
        PR2       = 24        ' Set PWM for 40KHz
        CCP1CON   = %00001100  ' Mode select = PWM
        T2CON     = %00000100  ' TMR2 ON 1:1  pre-scale
    Start:
       conversion
          B0 = 12
        SEROUT2  PORTB.1,Baud,[dec2 B0]
        PAUSE  1000
        GOTO    Start
    HERE IS RECEIVER IR .
    PIC16F84A
    include "modedefs"
    define osc 4
    PORTB = 00001111
    TRISB = 00001111
    B0 VAR byte
    MAIN:
    SERIN2 PORTB.3,16780,[DEC2 B0]' I GET STRANGE CHARACTERS OR NOTHINGS
    SEROUT2 PORTB.4,16780,[DEC2 B0], SEROUT2 IS SET WORKING GOOD
    GOTO MAIN
    HELLO
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
