LP Instant Interrupts Error
Results 1 to 8 of 8
    Perth, Australia
    What file versions of ReEnterPBP-18.bas and ReEnterPBP-18LP.bas are you using?
    DT_INTS-18 v3.3
    ReEnterPBP-18 v1.4
    ReEnterPBP-18LP v1.4
    Are your variables in an array?
    Are they being specified in a particular Bank?
    nope and nope.
    PBP creates extra variables for complex math or logical conditions.
    That must be what's causing my problem. It compiles OK when I take out a couple of fairly large SELECT CASE statements (one with 20 cases and the other with 12 cases). I guess i'll try to re-write my code so it will use less background PBP vars.
    The select case itself shouldn't add anything, no matter how many cases there are.
    But maybe the code in those cases ???
    Red face
    Whoops!
    Wait a minute.
    There I was asking you about file versions, and it turns out I was compiling with the wrong files.
    Ok, I'm getting can't fit errors too.
    I'll figure it out and get back.
    Perth, Australia
    Thanks DT.
    It looks like PBP has a bit of a problem with jigsaw puzzles.
    There really is room left in RAM, but PBP can't seem to fit the pieces together.
    The 256 bytes of RAM, are divided into BANKA and BANK0.
    Technically, from the PIC's point of view, it's all BANK0, and BANKA resides in the lower 128 bytes of BANK0.
    But PBP treats it like 2 separate banks.
    And for some reason, a BANK0 modifier messes up it's puzzle solving ability.
    For instance ...
    I've removed all the code from the programs, and only retained the variable declarations, which looks something like this.
    Using 18F1320.
    ; PBP system uses 26 bytes
    INT_System  VAR BYTE[26] ; from DT_INTS
    HP_Vars     VAR WORD[34] ; from ReEnterPBP-18
    LP_Vars     VAR WORD[34] ; from ReEnterPBP-18LP
    UserVars    VAR BYTE[25] ; vars declared in user's program
                             ; Total = 213 bytes, 43 bytes remaining
    RAMleft     VAR BYTE[43] ; use up remaining RAM
    The above compiles fine and uses up all 256 bytes of memory.
    So, all's well and good. You can add up any combination of arrays, bytes and words to fill up the RAM.
    Now let's remove the 43 byte RAMleft variable so there's plenty of room available.
    Then add a single byte variable, and specify BANK0 ...
    ;RAMleft     VAR BYTE[43] ; use up remaining RAM
    Bank0var    VAR BYTE BANK0
    When you compile the above ... you get an "Unable to Fit" error.
    There's 43 bytes left, but it couldn't fit 1 byte.
    Well actually, it can't fit UserVars now either. If you comment UserVars it will compile.
    Interestingly, if you then specify BANK0 for the UserVars, it can fit it again.
    UserVars    VAR BYTE[25] BANK0 ; vars declared in user's program
    And any additional variables will usually only fit if specified in BANK0.
    I've tried many variations of arrays, single bytes and combinations of both.
    It always comes down to whether ANY variables are specified in BANK0, anywhere in the program.
    After that, it won't automatically put anything else in BANK0, even after BANKA is full.
    For all the other chips with more RAM banks than a 1320, DT_INTS-18 "has to" specify some variables in BANK0.
    And because of the way PBP sorts the list of variables, LP_Vars usually gets the blame in the compiler error.
    I've tested all PBP versions back to 2.46 and the results are the same.
    Still with me ?<hr>
    So to try to actually answer your question ...
    In this circumstance (18F's with only 256 bytes), the best workaround I can see is to specify BANK0 for the variables in your program.
    You should be able to get another 43 bytes out of it.
    If you get close to the max, you may also need to manually put a couple in BANKA, just to squeeze in those last few.
    HTH,
    Last edited by Darrel Taylor; - 7th December 2009 at 02:05. Reason: wording and accuracy
    Perth, Australia
    Wow, a very comprehensive analysis there DT.
    Specifying BANK0 for all of my vars worked like a charm.
    Thanks very much for your help. Once again you have gone above and beyond.
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. Loop with two motor and 2 sensors
  3. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  5. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
