An 'ON...GOSUB' function would really be nice. Read a button, and handle it, without a whole list of IF..THEN's.![]()
That was quick
Im not using 'button', cause I'm using PCF8574's, but the ON...GOSUB will definately speed up my response code!
You're absolutely right. The SELECT...CASE function works better than an ON...GOSUB for reading a bank of buttons using PCF8574 (or a whole port). You can do the decode right there. Thanks! I never looked very closely at this instruction... at first glance I thought it was related to Upper/Lower case conversion... oops!
Thanks again
