can anyone here can convert this in picbasic pro?
Results 1 to 3 of 3
    Nov 2009
    Post can anyone here can convert this in picbasic pro?
    please help me to convert it in picbasic pro.. thanks
    * description :
    * This is a basic ultrasonic range finder, from 30 to 200 centimeters
    * target device :
    * PIC16F877A with 8 Mhz crystal
    * or any PIC with at least one ADC and PWM channel
    * configuration bits :
    * HS clock
    * no watchdog
    * no power up timer
    * no brown out
    * LVP disabled
    * data EE protect disabled
    * ICD disabled
    * see more details and schematic on http://www.micro-examples.com/
    * MACRO DEFINITIONS
    * ultra sonic pulse length in microseconds
    #define PULSELEN 300
    * circular buffer size for samples averaging
    #define BUFSIZE 10
    * LCD PORT
    * EasyPic2, EasyPic3 : PORTB
    * EaspyPic4 : PORTD
    #define LCDPORT PORTD
    #define LCDTRIS TRISD
    * GLOBAL VARIABLES
    unsigned char outOfRange ; // out of range flag : set when no echo is detected
    unsigned int buf[BUFSIZE] ; // samples buffer
    unsigned char idx = 0 ; // index of current sample in buffer
    * INTERRUPT SERVICE ROUTINE
    * This ISR handles TIMER1 overflow only
    void interrupt(void)
    if(PIR1.TMR1IF) // timer1 overflow ?
    outOfRange = 1 ; // set out of range flag
    PIR1.TMR1IF = 0 ; // clear interrupt flag
    * MAIN LOOP
    void main()
    ADCON1 = 0 ; // enables ADC
    TRISA = 0xff ; // PORTA as inputs
    PORTA = 0 ;
    TRISC = 0 ; // PORTC as outputs
    PORTC = 0 ;
    // TIMER1 settings
    T1CON = 0b00001100 ; // prescaler 1:1, osc. enabled, not sync, internal clk, stopped
    #ifdef LCDPORT
    // init LCD
    Lcd_Init(&LCDPORT) ; // use EP2/3/4 settings
    Lcd_Cmd(Lcd_CLEAR) ; // clear display
    Lcd_Cmd(Lcd_CURSOR_OFF) ; // cursor off
    Lcd_Out(1, 1, "UltraSonicRanger") ;
    Lcd_Out(2, 5, "cm") ;
    #endif
    // init PWM Channel : 40 Khz, 50% duty cycle
    PWM1_Init(40000) ;
    PWM1_Change_Duty(128) ;
    INTCON.GIE = 1 ; // enable global interrupts
    INTCON.PEIE = 1 ; // enable peripheral interrupts
    PIE1.TMR1IE = 0 ; // disable timer 1 interrupt
    PIR1.TMR1IF = 0 ; // clear timer 1 interrupt flag
    // forever
    for(;
    unsigned char i ; // general purpose byte
    unsigned long cm ; // distance in centimeters
    unsigned char str[4] ; // string for range display
    // prepare timer
    T1CON.TMR1ON = 0 ; // stop timer
    outOfRange = 0 ; // reset out of range flag
    TMR1H = 0 ; // clear timer1
    TMR1L = 0 ;
    T1CON.TMR1ON = 1 ; // start timer 1
    PIE1.TMR1IE = 1 ; // enable timer 1 interrupts on overflow
    // send pulse
    PWM1_Start() ; // enable PWM output : transducer is pulsed at ultrasonic frequency
    Delay_us(PULSELEN) ; // during PULSELEN microseconds
    PWM1_Stop() ; // stop PWM
    Delay_us(PULSELEN * 2) ; // do nothing for twice the pulse length duration to prevent false start
    while(Adc_Read(1) < 1) // while no pulse detected (no signal on ADC channel 1)
    if(outOfRange) break ; // to late, out of range
    T1CON.TMR1ON = 0 ; // stop timer 1
    PIE1.TMR1IE = 0 ; // disable timer 1 interrupts on overflow
    #ifdef LCDPORT
    if(outOfRange) // is overrange condtion detected ?
    Lcd_Out(2, 8, "OverRange") ; // display overrange message
    else if(TMR1H < ((PULSELEN * 6 * Clock_kHz()) / (1000 * 4 * 256))) // is underrange condition detected ?
    Lcd_Out(2, 8, "UnderRnge") ; // display underrange message
    else // good reading
    buf[idx] = TMR1H ; // build a 16 bit value from timer1
    buf[idx] <<= 8 ; // MSB
    buf[idx] += TMR1L ; // LSB
    // circular buffer
    idx++ ; // next location
    if(idx == BUFSIZE) // the end is reached ?
    idx = 0 ; // back to start
    cm = 0 ; // prepare centimeter averaging
    for(i = 0 ; i < BUFSIZE ; i++) // for all samples in buffer
    cm += buf[i] ; // add to sum
    cm /= BUFSIZE ; // average samples
    * cm contains now the number of clock cycles
    * from the start of the ultrasonic transmission
    * to the first echo detection
    * the duration in second is s = cm / (Clock_Khz() * 1000 / 4)
    * if we admit that sound speed in the air is 340 m/s
    * the distance in centimeters (forth and back) is d = s * 340 * 100 / 2
    * or d = 340 * 100 / 2 * cm / Clock_khz() / 1000 * 4
    * d = 34 * 2 / Clock_Khz()
    cm *= 34 * 2 ; // now converts to centimeters
    cm /= Clock_Khz() ;
    ByteToStr(cm, str) ; // convert to string
    Lcd_Out(2, 1, str) ; // print string
    Lcd_Out(2, 8, " ") ; // clear error message
    #endif
    Delay_ms(10) ; // 10 milliseconds delay before next sample
    --- nothing follows
    Wink
    Hi, ReianJim
    Do you know the Mikro C Compiler demo is free ... ( look in the Archives section for V 8.2 )
    My friend Bruno ( Brunog ) Will be glad to help you ...
    PS : How much do you offer for the translation ???
    This circuit may work, but I would put an amplifier on the receiving end. This could reach almost 10 meter on a good design.
    As for the translation, why not make it from scratch? You will learn something in the process.
    It is more than sure that the translation of a C program will have difficulties.
  1. Conversion from picbasic pro to hex for mplab
    By pr2don in forum Forum Requests
    Last Post: - 10th October 2010, 19:53
  2. picbasic pro and mplab IDE
    By soelinnhtet in forum mel PIC BASIC Pro
    Last Post: - 1st March 2010, 08:57
    Last Post: - 15th April 2007, 18:31
  4. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 17:15
  5. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 21:19
