PBP 2.6/MPLab 8.33 ASM "COD" error message
Results 1 to 10 of 10
    Apr 2009
    San Francsico
    Default PBP 2.6/MPLab 8.33 ASM "COD" error message
    Compile generates:
    Executing: "C:\PROGFILE\pbp\PBPMPLAB.BAT" -ampasmwin -oq -z -p16F690 "BLINK_16f690.BAS"
    Executing: "C:\PROGFILE\pbp\PBPW.EXE" -ampasmwin -oq -z -p16F690 "BLINK_16f690.BAS"
    PICBASIC PRO(TM) Compiler 2.60, (c) 1998, 2009 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Unable to access file D:\My Documents\PicBasicTrials\Blink\Blink_16F690\BLINK_ 16f690.COD
    Error processing COD file D:\My Documents\PicBasicTrials\Blink\Blink_16F690\BLINK_ 16f690.COD
    Halting build on first failure as requested.
    BUILD FAILED: Sat Jul 25 16:14:42 2009
    The project folder does not have a "blink_16f690.cod" file but has .asm, .mac, .err, .hex,.lst.
    Path has the mpasmwin path, C:\Program Files\Microchip\MPASM Suite\
    Installed "upgrade" into default directories and the MPASM & mePicBasic Pro toolsuite locations seem OK.
    Why is the .cod file missing?
    Can you reduce the filename of BLINK_16f690 to 8 Characters or less eg BLINK001 and see what happens?
    I've had problems with long filenames in the past (albeit I only compile from an XP DOS Box command line rather than from inside another program).
    Default .COD not supported in MPLAB > ver 8.15a
    See the Melabs web page http://www.melabs.com/support/index.htm
    Technical Support
    (01/26/2009) Microchip's MPLAB version 8.15a appears to be the last version that will support COD file functionality. This means that PBP will generate errors in MPLAB version 8.20 and later. The errors appear as:
    ERROR: Unable to access file...
    Error processing COD file...
    We will be releasing a new version of PBP with COFF file compatibility in response to this surprise move by Microchip. In the meantime, MPLAB version 8.15a is available for download here:
    Download MPLAB 8.15a (93M ZIP)
    Quote Originally Posted by BrianT View Post
    They did not fix that with 2.6PBP ?
    Default Where did you get PBP 2.60?
    Latest available PBP is ver 2.50c as far as I can tell.
    Cheers
    Brian
    Cheers
    Brian
    For some reason Melabs is not advertising it. But....
    http://www.rentron.com/PicBasic/prod...CBASIC-PRO.htm
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. PBP, ASM and LST files
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th January 2010, 14:43
  3. ASM or PBP First?
    By mackrackit in forum Off Topic
    Last Post: - 10th October 2009, 13:08
  4. pbp - asm variable passing
    Last Post: - 25th May 2009, 09:49
  5. asm and pbp
    By pic beginner in forum mel PIC BASIC Pro
    Last Post: - 24th October 2004, 06:33
