About USB
Results 1 to 7 of 7
Thread: About USB
    Sep 2009
    Default FTDI product VDrive2
    Dear Bill
    Can you pass a link about FTDI product VDrive2. I cant find it.
    Chris
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default Usb pic
    The FTDI site whilst visually neat is a logical mess and the Vdreive2 product is hiding under the 'Web Shop' button:
    http://apple.clickandbuild.com/cnb/s...ts+and+Modules
    The web shop uses the name 'Vinculum' but there is no explanation if this is the name of the shop, product group or whatever. It's amazing that a company with a good range of products and obviously of considerable technical expertise has names and parts probably designated by the mad hatter on one of his 'off' days.
    If this link does not work the way to find it is:
    1. FTDI site.
    2. Select Web Shop.
    3. Select 'modules'
    4. And there you are, I hope.
    When you get the module it will probably have outdated firmware loaded into it. My advice on dealing with this is:
    1. Don't update it initially.
    2. Write a test program to open files, write to the file, close, get file size and so on. All easy using RS232 at 9600 Baude without CTS/RTS control.
    3. After gaining confidence that the thing works, have a go at updating the firmware. I spent a whole day trying to do it by the 'memory stick method' and failed. I then had a go at update by using the RS232 link - and it worked fine.
    Updating by using RS232 needs the CTS/RTS lines to be used. There is a good circuit diagram and details on how to do it in the 'Firmware' support document. Don't bother asking questions from the tech support link - one does get a reply but, it's not of much value.
    If you go along this path and run into difficulties - let me know. i've just got a 2 Gigabyte stick and all works OK. It's odd writing data logging routines where there is no restriction on record lengths or the frequency of sampling!
    Regards Bill Legge
    Sep 2009
    Dear Bill
    Thanks for your reply and your comments. Ill let you know about my progess.
    Thanks again
    Chris
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. USB Bootloader.
    By HenrikOlsson in forum USB
    Last Post: - 2nd May 2013, 03:46
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  4. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 01:04
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 18:39
