Thanks again Dave that explains it perfectly :-)
Are there fast methods to determine the oscal as well as the current fuse setting of the pic by command line or otherwise ?
Dennis
Dennis
No. The configuration word is only accessible during programming. See section 9.1 of the datasheet.
Why would you need to see the OSCCAL value? Just make sure you have set the programmer so it does not erase the last word and use the Define to load it into the OSCCAL register. It would behoove you to actually read and digest the manual and datasheet before asking so many meaningless questions.
