PIC16F819 LED not blinking
Results 1 to 16 of 16
    Oct 2009
    Austin, Texas
    @ __CONFIG _INTRC_IO & _WDT_OFF & _PWRTE_OFF & _LVP_OFF & _MCLR_OFF & _BODEN_OFF
    This gives me illegal character "&" error message......asm.51
    So I need to go and make these settings permanent in MPASM file to keep from having to make this statement, correct?
    Also, datasheet (DS39598E)2004 shows:
    A. WDT is WDTEN (Watchdog Timer)
    B. MCLR is MCLRE (Memory Clear)
    C. BODEN is BOREN (Brown-Out)
    Is this correct?
    Thanks for the info Bruce....I appreciate all the help I can get.
    I will try to change the file settings...can you tell me what to have for pic16f819.inc file, I think I messed mine up.
    Here is mine:
    ;* 16F819.INC *
    ;* By : Leonard Zerman, Jeff Schmoyer *
    ;* Notice : Copyright (c) 2004 microEngineering Labs, Inc. *
    ;* All Rights Reserved *
    ;* Date : 01/07/04 *
    ;* Version : 2.45 *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    include 'M16F81x.INC' ; PM header
    device pic16F819, intrc_IO, wdt_off, pwrte_off, lvp_off, protect_off
    XALL
    NOLIST
    LIST
    LIST p = 16F819, r = dec, w = -302
    INCLUDE "P16F819.INC" ; MPASM Header
    __config _INTRC_osc & _WDT_OFF & _PWRTE_ON & _LVP_OFF & _CP_OFF
    NOLIST
    LIST
    I have no clue what this error message is. What assembler are you using?
    asm.51
    Almost looks like you're trying to use an 8051 assembler?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Oct 2009
    Austin, Texas
    I am using PICBASIC PRO from MicroCode Studio.
    In the settings window, I have selected the MPASM assembler checkbox.
    This is all I know. I reset the .inc file to where is was originally. Here it is....
    ;* 16F819.INC *
    ;* Version : 2.45 *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    device pic16F819, hs_osc, wdt_off, pwrt_off, lvp_off, protect_off
    XALL
    NOLIST
    LIST
    __config _HS_OSC & _WDT_OFF & _PWRTE_ON & _LVP_OFF & _CP_OFF
    NOLIST
    LIST
    I have been trying to get this MPASM Header, the way you wrote it, to compile correctly all day, but it still gives me errors.
    Oct 2009
    Austin, Texas
    This compiles without error.....
    @__CONFIG_HS_OSC_WDT_OFF_PWRTE_ON
    But more than this will cause a "Label truncated at 32 characters" error.
    Try the config line I posted above. What you're trying to do here isn't any good.
    -Bruce
    tech at rentron.com
    Oct 2009
    Austin, Texas
    Okay...I now understand what is to be done, and the changes were made as you said to the .inc file. Compile is now error free. Pop-up window settings are now as per your suggestion. Sorry for the crazy rookie mistakes. Let's see what happens now....
    Update...LED is on steady. No blinking
    Last edited by ronbowalker; - 30th November 2009 at 23:57. Reason: Info Updated...
    You might want to try something like this to see your LEDs blink;
    @ __CONFIG _INTRC_IO & _WDT_OFF & _PWRTE_OFF & _LVP_OFF & _MCLR_OFF & _BODEN_OFF & _DEBUG_OFF
    OSCCON = %01100000  ' 4MHz
    ADCON1=7
    TRISA = %00000000
    TRISB = %00000000
    TRISB.4 = 0
    TRISA.0 = 0
    PORTA.0 = 0
    PORTB.4 = 0
    LOOP:
      PORTB.4 = PORTB.4 ^ 1
      PAUSE 250
      PORTA.0 = PORTA.0 ^ 1
      PAUSE 250
      Goto LOOP
    Check your PBP manual to see why your LEDs aren't visibly blinking with PULSEOUT...;o)
    -Bruce
    tech at rentron.com
    If you prefer to edit your 16F819.INC file, then just change it to;
    If not, then just comment it out in the .INC file & add your config settings to your code.
    Melanie posted a nice intro here http://www.picbasic.co.uk/forum/showthread.php?t=543 on setting config options.
    NOTE: This applies only to the 16F819.INC file in your PBP directory. Not the P16F819.INC
    file in your MPLAB directory. These are different. You shouldn't ever need to modify the
    P16F819.INC file in your MPLAB directory.
    -Bruce
    tech at rentron.com
  1. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 07:19
  2. Blinking an led problem on P16F84
    By aimenbukharie in forum General
    Last Post: - 20th March 2009, 06:00
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. LCD will not start
  5. simple LED Blinking project
    Last Post: - 11th December 2004, 02:25
