Your config options have ZERO effect on actual config settings.
So your config settings are whatever the default config options are set to in yourCode:@__Config_INTRC_OSC @__Config_PWRT_OFF @__Config_MCLR_OFF @__Config_BOREN_OFF @__Config_DEBUG_OFF
PBP 16F819.INC file for the MPASM assembler.
And, like Melanie mentioned, you for sure will want the WDT disabled since DEFINE OSC 3
is for a 3MHz osc & not 32kHz osc, so your timing is way off.
Try this just to verify it's working;
And, for PBP 2.6 you'll want to change LOOP to something like LOOPS since LOOP is now aCode:DEFINE OSC 4 @ __CONFIG _INTRC_IO & _WDT_OFF & _PWRTE_OFF & _LVP_OFF & _MCLR_OFF & _BODEN_OFF & _DEBUG_OFF OSCCON = %01100000 ' 4MHz ADCON1=7 TRISA = %00000000 TRISB = %00000000 TRISB.4 = 0 TRISA.0 = 0 PORTA.0 = 0 PORTB.4 = 0 LOOP: PULSOUT PORTB.4,20 PAUSE 20 PULSOUT PORTA.0,20 PAUSE 20 Goto LOOP
reserved word.
