Why doesn't this servo code work?
Results 1 to 4 of 4
    Dec 2009
    Smile Why doesn't this servo code work?
    I am trying to use this simple servo code on a 16F684 using portc.1. What am I missing? Why doesn't it work? All that happens is the servo twitches when downloading the hex file, then that's all.
    OSCCON = %01100001 '4 Mhz on internal osc
    TRISC = %00000000
    PORTC = %00000000
    x var byte
    y var byte
    for x = 0 to 50
    pulsout portc.1, 75
    pause 20
    next x
    pause 2000
    for y = 0 to 50
    pulsout portc.1, 175
    pause 20
    next y
    pause 2000
    Wink
    The answer is in your Datasheet ...
    PortC1 is shared with the on chip ADC ... so you must tell the chip you want to use it as a DIGITAL pin ...
    BTW ... Comparator also shares this pin ... soooo ...
    Two datasheet sections to review ...
    Dec 2009
    Default Thanks!
    Thanks! That helps a lot. I use a lot of different PIC chips
    and it's been a long while since I used a 684. I thought I
    had remembered all the details.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  3. Replies: 3
    Last Post: - 1st July 2008, 21:07
  4. Problem with 12F629, servo and EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2008, 09:53
  5. Servo Code problem
    By ALFRED in forum General
    Last Post: - 2nd March 2006, 03:30
