PICBasic Pro 2.50c on Win 7 - ERROR: Unable to execute mpasmwin.
Results 1 to 4 of 4
    Dec 2008
    Default PICBasic Pro 2.50c on Win 7 - ERROR: Unable to execute mpasmwin.
    Hi All.
    I am using PBP 2.50c and am waiting for PBP 2.60 upgrade to be delivered.
    Getting back to PIC USB programming after about a six month break between projects. I put together another PIC 18F2550 circuit fairly easily that works on old code created (Thanks again Darrel Taylor), but when I went to edit and re-compile the code, I get the following error, no matter what:
    I have changed the directory to something shorter and without any spaces in the name. After a search in this forum, the following link is referred to, but after installing the MPLab plugin, I do not find the stated BAT file in the PBP install directory.
    http://www.melabs.com/support/mplab.htm
    THEN, after giving up hours later on MPLab, I re-installed Microcode Studio and when this program goes to compile, it errors stating that it cannot create a Run.bat file.
    Any ideas? Any help is appreciated.
    Dec 2008
    Default Doh!!!! Figured Out MPLab Error Problem
    Figured out MPLab, I think. After getting some zzzzzzs, re-read the page on Melabs to see that those instructions referred to PBP 2.60 or later. (Ordered the PBP 2.60 update CD last night, so have to wait a couple weeks for that.) So went to the earlier version page to see that 2.50c is only compatible with MPLab v8.15a or earlier.
    Still haven't figured out what is wrong with MCS though.
    Any help with Microcode Studio?
    Wink
    Hi, KCy
    May be re-do the MCS Compiler auto - search ...
    Dec 2008
    Default MCS Figured Out On Win7
    Need to run as Administrator. Right click on the icon and select run as admin.
  1. Unable to execute mpasmwin
    By oldmainframer in forum General
    Last Post: - 18th December 2016, 00:01
  2. 16F636 Picbasic pro 2.60 / MPLAB 8.43 / Windows 7
    By mathubbard in forum mel PIC BASIC Pro
    Last Post: - 19th February 2010, 16:50
  4. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 18:15
  5. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 22:19
