OSCON setting for 18F4520
Results 1 to 9 of 9
    The PLL multiplyer will multiply x4 whatever your OSCILLATOR is running at. There are no other options... it's either x4 or OFF.
    You need a 5MHz Crystal or Resonator if you want 20MHz using the PLL Multiplier.
    The Internal Oscillator does not have 5MHz as one of it's selectable options (neither does it have 20MHz).
    So if you WANT 20MHz, you'll need a 20MHz Xtal or Resonator, use HS Mode and have the PLL multiplier OFF (or 5MHz Xtal or Resonator, HS Mode and have the PLL multiplyer ON).
    Section 2, Datasheet DS39631A explains it in great detail (for the 18F4520 chip) which you said you were using at the start of this thread.
    Default got it !
    Thank Melanie and everyone else who replied to this thread !
    It is all CRYSTAL CLEAR now !!
    Thank a million
  1. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 14:01
  2. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 07:24
  3. code size VS speed optimization setting?
    Last Post: - 28th April 2008, 14:38
  4. Setting up the oscillator
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2007, 14:53
  5. Help with setting adcon1 for 16f877
    Last Post: - 16th August 2005, 11:13
