A quick way...
Results 1 to 6 of 6
Thread: A quick way...
    Jul 2009
    That sounds perfect, since the pulse could be a short as 2 uS. I am using a PIC12F509 and if you could please give me an example for this one I will really apreciate it...
    By the way, what I need is to toggle pin GPIO.2 from 1 to 0 when this pulse arives in GPIO.1 and this should be as fast as possible, since the actual 1 to 0 edge is used to measure distance.
    Then really neither of the above replies are suitable.
    This is because whilst you are away doing something, (for example the PAUSE instruction), you are not looking for the event in order to trigger your Output IMMEDIATELY. Even with my suggested modification, you won't miss the pulse, BUT you'll only do something about it some time later - and that time could be delayed by anything up to 1mS.
    You would need something like Darrel's INSTANT INTERRUPTS - but NOT to Poll the input pin, but to give you your Timeout. If setting your Output pin relative to the Input trigger is so critical, then I would even consider if a PIC is the suitable device - you could do it quicker with discrete logic.
  1. Quick n dirty HPWM out of phase
    Last Post: - 17th August 2014, 05:29
  2. Quick DS18B20 question
    By gti_uk in forum General
    Last Post: - 21st June 2009, 17:24
  3. Quick USB CRC5 question
    By Michael Wakileh in forum USB
    Last Post: - 12th June 2009, 04:23
  4. Two quick (and elementary) questions.
    By scorpion990 in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 23:03
  5. Interrupt Quick Question
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 05:51
