Blink LED / toggle output with causing a software delay
Results 1 to 11 of 11
    Nov 2009
    Post
    Really sorry about the delay in getting this up - major problems with my one and only 12F629 - lost the 'OSCCAL' number when programming,
    somehow... -- so re-compiled it for a 12F509.
    It's long-winded I know, but it works with steady outputs in conjunction with 2 x FLEDS or flashing LED's.
    In the listing, there are 4 lines of commented (tried & unused) code for a simple 250ms on - 250ms off, port toggle for each LED output.
    Of course, this is useless, as the program spends all it's time, toggling outputs..
    No components involved, other than a 3 resistors for LED's, if you want to put some on GPIO.2 / GPIO.4 & GPIO.5 as status indicators to 0V.
    The 2 switch inputs are single-pole tactile types pulled active LOW.
    Switch input pins are GPIO.0 & GPIO.1 - all pin details in the listing.
    Just need to get 2 standard LED's flashing @2Hz on the outputs, without this affecting the switch input 'scan' routine.
    Many thanks all
    You know in programming and Computers there's no such thing as "immediate" or "without delay". Even the world's fastest supercomputer still takes time to execute an instruction. Now the big decision is "How fast is fast enough"?
    If it's Push-Buttons (ie human involvement), then 1mS is more than adequate time to kill before detecting that a Button has been pressed. If it's an Optical Sensor detecting a Bullet whizzing past it, then obviously 1mS is totally inadequate.
    So let's pretend that we can afford to waste 1mS keeping time without missing a Button Press... so what we'll do is have our MainLoop keeping our 250mS toggle continuously in 1mS steps, and in between those 1mS steps, we'll do all our checking and counting...
    Break it all down into easy manageable processes... I've not included any code for disabling Comparators or ADC's or Voltage Refernce modules... that's up to you with your chosen PIC whatever it may be...
    	CounterSmall var BYTE			' 1mS Counter
    	CounterBIG var BYTE			' 250mS Counter
    	SystemFlags var BYTE
    		LEDToggle var SystemFlags.0	' LED Toggle Flag
    		OutputAFlag var SystemFlags.1	' Button A Active Flag
    		OutputBFlag var SystemFlags.2	' Button B Active Flag
    	ResetPulse con 40			' Length of time of RESET Output
    						' calculated in steps of 250mS
    	'	Hardware Defines
    	InputA var GPIO.0
    	InputB var GPIO.1
    	OutputA var GPIO.2
    	OutputB var GPIO.4
    	OutputReset var GPIO.5
    Initialise:
    	TRISIO=%00001011
    	Low OutputA
    	Low OutputB
    	Low OutputReset
    	CounterBig=0
    	SystemFlags=0
    MainLoop:
    	'	Detect Button A
    	If InputA=0 then
    		OutputAFlag=1
    		OutputAFlag=0
    	'	Detect Button B
    	If InputB=0 then
    		OutputBFlag=1
    		OutputBFlag=0
    	'	Process LEDA
    	If OutputAFlag=1 and LEDToggle=1 then
    		High OutputA
    		Low OutputA
    	'	Process LEDB
    	If OutputBFlag=1 and LEDToggle=1 then
    		High OutputB
    		Low OutputB
    	'	Process RESET Output
    	If OutputAFlag=1 then
    		If OutputBFlag=1 then
    			If CounterBIG=0 then
    				OutputRESET=1
    				CounterBIG=ResetPulse
    	If CounterBIG=0 then OutputRESET=0
    	'	Keep Time
    	Pause 1
    	CounterSmall=CounterSmall+1
    	If CounterSmall=250 then
    		LEDToggle=LEDToggle^1
    		If CounterBIG > 0 then CounterBIG=CounterBIG-1
    	Goto MainLoop
    Now the above Code applied to have the LED's blinking ONLY whilst the Buttons are pressed.
    Re-reading your posts, I'm not sure if you want them to LATCH-ON and only reset once the 10-Second Pulse resets everything... in which case you need a small variant of the above...
    	'	Hardware Defines
    	InputA var GPIO.0
    	InputB var GPIO.1
    	OutputA var GPIO.2
    	OutputB var GPIO.4
    Initialise:
    	TRISIO=%00001011
    	Low OutputA
    	Low OutputB
    	Low OutputReset
    	CounterBig=0
    	SystemFlags=0
    MainLoop:
    	'	Detect Button A
    	If InputA=0 then OutputAFlag=1
    	'	Detect Button B
    	If InputB=0 then OutputBFlag=1
    	'	Process LEDA
    		High OutputA
    		Low OutputA
    	'	Process LEDB
    		High OutputB
    		Low OutputB
    				OutputRESET=1
    	'	Keep Time
    	Pause 1
    				OutputAFlag=0
    				OutputBFlag=0
    	Goto MainLoop
    Nov 2009
    Thumbs up
    Thank you so much Melanie
    What is more, it works perfectly ! - assembled 1st time, with no errors.
    At one stage, I did actually think about using an incremental counter, with a Gosub/Return statement in the switch monitoring loop, to check the value of the counter and take appropiate action.
    However, the problem still remained of having to 'toggle' the O/P's on & off for 250ms each (and the huge delays using the combined TOGGLE & PULSOUT commands).
    Your solution is very clever - I guess simlilar to 'multiplexing' a multi-digit 7-segment LED display, when only 1 digit is on at any one time, - 'persistance of vision' fools your brain into thinking they are all on at once !
    I'll let you know how I get on 'tweaking' the code & post the results here.
    Thanks again
    Wink a little Thank you ...
    Eveybody Sing with me :
    " ain't no sunshine when she's gone, ....." *big smile* - Melanie
    exagerated a little bit ... yes, might be .
    But soooo small a bit !!!
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  4. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  5. LCD will not start
