@ SLEEP with interrupts 16F88
Results 1 to 8 of 8
    drewlash's Avatar
    drewlash Guest
    Default @ SLEEP with interrupts 16F88
    I am working on a project involving two 16F88 chips. I am using the hardware usart. I need to put the chips to sleep and have them wake up with the interrupt pin RB0 or the RX interrupt.
    This is part of the code
    Main_Prog:
    IF MAIN_INT THEN ' RB0 HIGH
    GOSUB Handle_Buttons
    IF PIR1.5 THEN ' USART RECIEVE INTERRUPT FLAG
    GOSUB Rx_Sub
    INTCON = %11010000 ' SET GIE, PEIE, AND INTE
    PIE1 = %00100000 ' SET RCIE
    PIR1 = %00000000 ' CLEAR INTERRUPT FLAGS
    OPTION_REG = %11000000 'PULL UPS ENABLED
    @ SLEEP
    GOTO Main_Prog
    If I take all the code from intcon to @sleep out (last 5 lines in Main_Prog), then it works perfectly, however, as soon as I start putting those lines back in, I get different, inconsisten results each time.
    It appears that the RB0 interrupt works, however, the chip will never wake up with the USART Recieve Interrupt. It also appears that with the sleep in there, it no longer sends the usart signals.
    If anyone has any ideas on what may be wrong or any tips on using the usart recieve interrupt, it would be greatly appreciated.
    Andrew Lash
    what about your USART and others define???
    can you post your WHOLE code.
    drewlash's Avatar
    drewlash Guest
    The program is too long to post all of it. Below I'll post the code related to the usart use.
    DEFINE HSER_CLROERR 1
    DEFINE HSER_RCSTA 90h
    DEFINE HSER TXSTA 20h
    DEFINE HSER_BAUD 9600
    'this is at the beginning of the code, before it enters the main loop.
    'Disable interrupts
    INTCON = %00000000
    PIE1 = %00000000
    PIR1 = %00000000
    'Send/Recieve Codes
    GROUND_ALL CON $00
    ANT_1_SELECT CON $01
    ANT_2_SELECT CON $02
    ANT_3_SELECT CON $03
    ANT_4_SELECT CON $04
    ANT_REQUEST CON $09
    RADIO_SENSE_OFF CON $10
    RADIO_SENSE_ON CON $11
    REQUEST_MODE CON $12
    REQUEST_RF CON $13
    RF_SENSED_OFF CON $14
    RF_SENSED_ON CON $15
    RF_SENSED CON $16
    RADIO_OFF CON $17
    Send_Code VAR BYTE 'Var to pass to the send routine
    RX_Code VAR word 'Var to get the code from the remote
    Tx_Sub:
    hserout ["M", send_code]
    Rx_Sub:
    HSERIN [rx_code.byte0, rx_code.byte1]
    gosub Handle_RX
    Handle_RX:
    if rx_code.byte0 = "R" then 'Make sure code is from remote
    if rx_code.byte1 = Ground_ALL then 'command recieved to ground all
    'code for ground all
    ' repeat for each command
    The send/recieve works fine if the sleep isn't in there. As soon as I try putting the chips to sleep, it stops working.
    drewlash's Avatar
    drewlash Guest
    No matter what I do, I just can't get the chips to wake up from the recieve interrupt. Has anyone ever used the 16F88 with the USART receive interrupt successfully? What am I doing wrong? Any ideas? My program receives the data fine as long as I don't try putting it to sleep. The RB0 interrupt pin will also work to wake it up from sleep, but not the RCIE interrupt.
    I've been stuck on this for over a week now. Any help would be greatly appreciated!
    Andrew Lash
    not sure of it but... what about if you change
    to
    RCSTA=$90
    TXSTA=$20
    SPBRG = 32 ' if you osc=20
    drewlash's Avatar
    drewlash Guest
    That doesn't change the operation of the program at all, just tried it, and nothing changed. The receive interrupt still does not work.
    Andrew Lash
    The USART can only wake this device from SLEEP when used in (Synchronous Slave Mode).
    Peripherals that rely on the on-chip clock (like the USART in Asynchronous mode) cannot generate interrupts, since during SLEEP, no on-chip clocks are present.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    mmm, interesting Bruce. I never check the datasheet for that because i've never never never use USART interrupt to wake-up an application... great to know that!!
    SO, The choice you have is to use the interrupt on PORTB change. In the interrupt handler, check if it's an RB0 or other. Link another PORTB pin to the USART RX and that's it... in this case it will be safer to send one or few "header character" to ensure getting all data from your PC.
    There's maybe some other way to do that but this is the only one who comes here... can also be done with some FlowControl pin on the DB9...
  1. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  2. 18F1220 LCD and Sleep
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 13th July 2008, 19:58
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 11:21
  4. help
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2005, 21:42
  5. Need once your help one please
    Last Post: - 9th February 2005, 21:33
