Transformerless Power Supply of 1A at 5Volts!
Results 1 to 23 of 23
    elipee's Avatar
    elipee Guest
    Default Re: Transformerless Power Supply of 1A at 5Volts!
    Very interesting circuit, however, a think it is not going to work very well, look at T2 ( BUZ41A or IRF730) , both have a maximum 20V VGS, so when voltage get bigger than 20 , T2 gate get damage. Maybe it work for a time, but T2 VGS is out of specification.
    It won't get that high for long time to destroy the Mosfet. Also the Zener is not a switch but it does start to operate at lower that rated voltage.
    It does work with great success and efficiency.
    If you are concerned about Vgs, there are other Mosfets (sure more expensive) to replace this one.
    Sep 2014
    "voltage at few places seem to be as high as 280-300V"
    No so.
    Do you realise the current taken by a globe (and lots of other devices) will increase considerably as the voltage increases. When the voltage rises by say 10%, the current will rise by much more than 10% and this will put a very heavy burden on the generator and in most cases the generator will not be able to supply the load. This is why the voltage will not rise as you have stated.
    Globes and radiators are not linear devices, but if they were, a 1,000 watt radiator at 250v would take 1250 watts at 280v. This is 25% increase in wattage for 13% increase in voltage.
    The figures would be much higher for 230v supply.
  1. Transformerless Power Suppply
    By ERIK in forum Schematics
    Last Post: - 3rd September 2012, 15:08
  2. PIC backup power supply: switchover ???
    Last Post: - 18th April 2008, 17:05
  3. Transformerless Power supply
    By nikhil in forum mel PIC BASIC Pro
    Last Post: - 17th January 2007, 07:07
  4. Replies: 10
    Last Post: - 16th October 2006, 18:23
  5. Transformerless Power Supply
    By volkov in forum General
    Last Post: - 2nd July 2006, 23:13
