Transformerless Power Supply of 1A at 5Volts!
Results 1 to 23 of 23
    Default Transformerless Power Supply of 1A at 5Volts!
    The topic of P.S. direcly from the mains is very dangerous and I do not recommed to do so.
    But there are cases that this is unavoidable.
    Current designs have the dis-advatage that are of low current.
    The attached one is a clever design from Elektor and gives about 1A at 5Volts.
    I repeat that all parts are live and should never be touched!
    Miami, Florida USA
    Ioannis,
    Unless I am missing something here, K1 in your schematics seems to be a transformer. The datasheet for the LM2595 gives a maximum input voltage for this chip of 40V. If K1 is not a transformer, it looks like you would fry this chip with a power supply input of 230Vac.
    Robert.
    K1 is a connector!
    As for the 2595, yes you are right on the max input voltage. BUT, look carefully at the schematic.
    The 2595 will get a max of 40 volts and nothing more than this. Zener, T1 and T2 will make sure that it stays in safety region.
    Thats why I stated that the circuit is clever.
    Miami, Florida USA
    Ioannis,
    Yes, you are right about T1 and T2 keeping the voltage low on the LM2595 chip. However, I am still not convinced with this circuit. After looking at the datasheet for T2, it seems to me like the Drain and the Source inputs should be swapped for a proper grounding on LM2595. The current should be flowing away from the ground in LM2595, not towards it.
    Also, the maximum VGS voltage on T2 is 20V, so if for some reason T1 fails T2 would also be fried. I don't know why Elektor designed this circuit without a transformer, and I agree with you that this is very dangerous.
    Technically the circuit is correct. No need for pin swaping. It is OK as it is.
    At first I know it is a bit confusing but trust me it is very clever trick.
    The purpose of zener and the 2 transistors is to let the voltage raise up to say 40 volts on the capacitor and 2595 input. Then T1 is biased and switches off T2 so that the raising voltage cannot hurt the 2595.
    This is repeated again on the next half period.
    As for the dangerous this refers to the live voltages all over the circuit and the circuits connected to this. Other than this I consider it "safe" in a matter of speaking to use it.
    Wink Microchip has examples...
    The Microchip website has examples of running micros off the AC line... search the app notes...
    Not at 1A though...
    Quote Originally Posted by mtripoli View Post
    Nov 2009
    London
    Question
    I know some places have extreme voltage drop. Will this circuit work if AC voltage drops to lets say 160V from 230V & also if it rises to Lets say 300V from 230 V? Thanks
    Jan 2006
    Istanbul
    Quote Originally Posted by Megahertz View Post
    In what place of earth can municipal power lines go from 230V to 300V?
    I can understand 240 or even at max 260, but 300? Such a case would end up for compensation in court.
    The circuit will work from say 10 Volts AC up to whatever the rated voltage of the componets used is, mainly the bridge.
    So the answer is yes.
    Quote Originally Posted by sayzer View Post
    Hi Sayzer,
    Probably depends upon how you measure it. If you use an a/c voltmeter then it is calibrated in RMS and gives accurate results. If he is using a D/C voltmeter and a diode, then he is seeing peak voltage - diode drop, and will see an inaccurately high value.
    Nov 2009
    London
    The country in question is India. When I was there, I actually saw the voltage drop upto 170V and during power faliure when the backup generators were fired up, voltage at few places seem to be as high as 280-300V and so I asked the question just to have the knowledge
    Default Re: Transformerless Power Supply of 1A at 5Volts!
    The circuit of Elektor will NOT work when input voltage is rising above 39 or so volts. So it will work perfectly well if input AC voltage is just up to 110. No need to change anything, or almost anything. May be just the R5 changed to a lower value, say 15 ohms.
    The circuit is very clever and the SMPS is disabled by the pass transistor wheninput voltage is greater than 39 so volts. Beware it is not isolated.
    Nov 2013
    Did anyone try to build this circuit? Can this work at 230v AC
    It is mainly for 230 VAC
    Nov 2013
    It is not AC but rectified AC to result in DC. Also note the Zener that drops the voltage.
    Please review the circuit more carefully. The circuit works from zero up to about 39 volts. After that point it cuts off.
    It works very good from 230 VAC.
    Feb 2004
    Michigan, USA
    Be interesting to see what happens from 90Vac to 304Vac.
    Agreed, I'd be interested in 110VAC range.
    Edit: Did you guys check Melanie's design?
    http://www.picbasic.co.uk/forum/show...7531#post17531
    Quote Originally Posted by jmgelba View Post
    As I said it does not do anything above 39 or so volts. So where is the problem?
    After the sine wave has reached the 38-39 volts the circuits is not powered any more from the power line.
    elipee's Avatar
    elipee Guest
    Very interesting circuit, however, a think it is not going to work very well, look at T2 ( BUZ41A or IRF730) , both have a maximum 20V VGS, so when voltage get bigger than 20 , T2 gate get damage. Maybe it work for a time, but T2 VGS is out of specification.
    It won't get that high for long time to destroy the Mosfet. Also the Zener is not a switch but it does start to operate at lower that rated voltage.
    It does work with great success and efficiency.
    If you are concerned about Vgs, there are other Mosfets (sure more expensive) to replace this one.
    Sep 2014
    "voltage at few places seem to be as high as 280-300V"
    No so.
    Do you realise the current taken by a globe (and lots of other devices) will increase considerably as the voltage increases. When the voltage rises by say 10%, the current will rise by much more than 10% and this will put a very heavy burden on the generator and in most cases the generator will not be able to supply the load. This is why the voltage will not rise as you have stated.
    Globes and radiators are not linear devices, but if they were, a 1,000 watt radiator at 250v would take 1250 watts at 280v. This is 25% increase in wattage for 13% increase in voltage.
    The figures would be much higher for 230v supply.
  1. Transformerless Power Suppply
    By ERIK in forum Schematics
    Last Post: - 3rd September 2012, 15:08
  2. PIC backup power supply: switchover ???
    Last Post: - 18th April 2008, 17:05
  3. Transformerless Power supply
    By nikhil in forum mel PIC BASIC Pro
    Last Post: - 17th January 2007, 07:07
  4. Replies: 10
    Last Post: - 16th October 2006, 18:23
  5. Transformerless Power Supply
    By volkov in forum General
    Last Post: - 2nd July 2006, 23:13
