Dual instance with MPLAB 8 ?
Results 1 to 11 of 11
    May 2009
    Saint-Quentin-en-Yvelines, FRANCE
    Default Dual instance with MPLAB 8 ?
    Hi everybody,
    I think I already know the answer but does anybody know if it possible to run simultaneously two instances of MPLAB 8 on the same PC (under Windows 7) ?
    I get an error message when i try to launch a second copy of MPLAB 8 if a first one is already running.
    Any ideas ?
    Thank your for help.
    MikeBZH
    Aug 2011
    Default Re: Dual instance with MPLAB 8 ?
    Do you get an error message or a warning?
    I've done it in the past. I think you need to have different workspaces and different debugger tools (ie PK3 and ICD3) from what I remember.
    No, you cannot because of share violation errors. Also MPLAB gives a warning that this is not recommended.
    Aug 2011
    Yes, you can. I have three instances running right now.
    Just launch it from an mplab project (.mcp file) and not a generic shortcut.
    It IS easy to get it confused. I prefer to use different machines.
    Oh, I see. The MPLAB sees the first workspace so gives a violation error message.
    By your suggestion, you've already defined a new workspace, so MPLAB is happy!
    Good one,
    Aug 2011
    For this to work I think you need to have one-to-one project-workspace enabled (MPLAB main menu Configure | Settings... | Projects | Use one-to-one project-workspace model).
    It's of limited use since you have to use different debug/programming tools in each project (ie Pickit3 in one, ICD3 in another). You can't use two of the same type. For that you'd need to use MPLABX.
    May 2009
    Thank you for your answers. I am going to try this.
    I have two screens on my computer so I think I will not be confused. One instance on each.
    My purpose is only to copy and paste some source code from one program to the other so this is quite simple.
    MikeBZH
    Aug 2011
    If that's all you want to do then any text editor would work (ie Notepad)
    May 2009
    Hi Tumbleweed,
    Not exactly. The tabs are not the same as with the MPLAB editor and you spend some time to realign everything.
    MikeBZH
    Aug 2011
    There are lots of better text editors out there, like notepad++ https://notepad-plus-plus.org/ and it's free.
    For that matter, the MPLAB editor can open multiple source files (ie multiple windows) at the same time without having to run multiple copies. That way your editor settings would stay the same without having to setup anything.
    May 2009
    Thank you Tumbleweed.
    Simple but very interesting solutions.
    In France we have a cartoon called "the Shadoks". They always say : "Why to do you want to make it simple when you can make it complicated ?" Am I a Shadok ?
    MikeBZH
  1. Dual power source
    By Demon in forum Off Topic
    Last Post: - 12th January 2014, 14:16
  2. How to support two (dual) USB ports?
    Last Post: - 19th January 2012, 00:36
  3. Clock and Dual Termometer
    Last Post: - 3rd February 2011, 17:17
  4. Dual clock speeds on a PIC
    Last Post: - 24th January 2008, 01:34
  5. MCP4922 Dual DAC
    By J_Brittian in forum mel PIC BASIC Pro
    Last Post: - 25th October 2005, 18:39
