Interrupt question
Results 1 to 5 of 5
    The interrupt flag will be set as soon as TMR1 overflows but PBP won't "see" it until the PauseUs statement is completed. Hence, the ISR won't be executed until after the pause.
    Using DTInts won't give you that problem.
    Apr 2006
    GearSweaterMountain, The Netherlands
    OK ! I will give the Dtint a try ...
    Thanks for the fast reply !
    Best regards,
    UB
    Apr 2006
    Just wondering. With the pbp ON INTERRUPT STATEMENT i could do a RESUME to a specific label.
    This is not possible with the DT int, right ?
    Sep 2005
    Campbell, CA
    DT interrupts can't return to a specific label - but you can set a flag inside the ISR and test for that in your main program loop. If set, you can jump to wherever you want.
    Although it isn't quite "instant", that method can usually accomplish what you need.
    Charles Linquist
  1. Can't ID interrupt source with this IntHandler??
  2. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  3. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
  4. USART interrupt not interrupting right
  5. Interrupt question
    By stone in forum mel PIC BASIC Pro
    Last Post: - 26th January 2005, 00:11
