SERIN2 freezes
Results 1 to 8 of 8
Thread: SERIN2 freezes
    Dec 2009
    Hi xnihilo,
    I think the problem is about STR, i mean PBP doesn't work well (not a bit) with strings.
    But, i have the same problem, SERIN2 freezes when i add a timeout and label of delay. This code doesn't work:
    'Purpose: How many delays do i have?
    myRX VAR PORTB.0
    myVar VAR BYTE
    data VAR BYTE
    CALL OnScreen
    loop:
            SERIN2 myRX,396,100,delay,[wait ("N"),data]
    GOTO loop
    delay:
            myVar=myVar+1
            CALL OnScreen
    OnScreen:
          lcdout $fe,1
          lcdout #MyVar
    the code doesn't go to delay label.
    Quote Originally Posted by KaanInal View Post
    Hmmm. Put the blame on the compiler when your code does not work?
    Maybe you need to look at the CALL section in the manual.
    And that RETURN right after that might not be helping either.
    Dec 2009
    Sorry for the misunderstanding it was not a blame, i love this compiler. I didn't find any string functions on my sources, if you knew some please tell me so i can change my sources with correct ones. It was an opinion.
    It was a part of my code but i don't understand what is wrong with the call? Should i use gosub? What do you suggest ?
    Also,
    there is an answer on this page: http://www.picbasic.co.uk/forum/show...highlight=idle
    xnihilo, is that solves your problem too?
    No problems
    The PIC it's self is not really a string type setup, but PBP gives it a good shot by treating strings as an array. The STR modifier is for that. Yes, more string handling might be nice, or a different way of handling them... But we are so limited on memory the way it is with most PICs that it may be a shot in the foot.
    CALL -- that is for "CALLING" an ASM function.
    The TIME OUT/GOTO label is just that. a GOTO.
    So wherever you send things after a serial time out do not use a RETURN.
    GOTO loop
    delay:
            myVar=myVar+1
            CALL OnScreen
    In the above case replace the RETURN with GOTO LOOP.
    Looks like that is what you want....
    Dec 2009
    I got it .
    Thank you by the way, that explains the "CALL and RETURN overflow" problems on my simulations .
    Glad to bof soivice
  1. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 09:47
  2. Getting SERIN2 to work?
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2009, 20:10
  3. SLOW Serin2 and Serout2
    By dragons_fire in forum General
    Last Post: - 26th June 2009, 02:38
  4. SERIN2 digit parsing
    Last Post: - 7th January 2007, 23:15
  5. SEROUT2 and SERIN2 commands
    By bangunprayogi in forum mel PIC BASIC Pro
    Last Post: - 4th August 2005, 09:03
