'based on: http://list.picbasic.com/forum/messages/6851/7091.html?1080565370
@ device pic16F684, intrc_osc_noclkout, BOD_OFF, PWRT_OFF, wdt_off, mclr_off, protect_off
'quid freq horloge requise?
DEFINE OSC 8 'set OSC value to 8MHz for instructions PAUSE, PAUSEus and SOUND (instead of default 4MHz)
DEFINE LCD_DREG PORTC 'data port out is portC
DEFINE LCD_DBIT 0 'data on portC0-portC3
DEFINE LCD_RSREG PORTC 'r/s is on portC.4, with 10K WPU
DEFINE LCD_RSBIT 4
DEFINE LCD_EREG PORTC 'enable is on portC.5
DEFINE LCD_EBIT 5
DEFINE LCD_BITS 4 '4bits data bus
DEFINE LCD_LINES 2 '2lines display
DEFINE LCD_COMMANDUS 2000 '2ms cmd delay
DEFINE LCD_DATAUS 50 '50us data delay
INTCON = 0 'disable interrupts and clear int flags
OSCCON = %01110001 'int osc, hs, 8mhz
CMCON0 = %00000111
ANSEL = %00000000
OPTION_REG = %11111111
'alias in SERIN2
GPSin VAR PORTA.0 'A0 has TTL levels
TRISA = %000001
TRISC = 0
PORTA = %000001 'A0 is used for gps input, SERIN2 bitbanging (software eusart)
PORTC = 0
WPUA = 0
mystring var byte[65]
i var byte
'programming custom characters
LCDOUT $FE,$40,$00,$0A,$0A,$00,$11,$0E,$00,$00 ' Cust Char #0: happy smiley
LCDOUT $FE,$48,$0E,$15,$1B,$19,$1B,$15,$0E,$00 ' Cust Char #1: copyright
LCDOUT $FE,$50,$0E,$0E,$1F,$0E,$04,$00,$1F,$00 ' Cust Char #2: press
LCDOUT $FE,$58,$0A,$1F,$1F,$1F,$0E,$04,$00,$00 ' Cust Char #3: heart
LCDOUT $FE,$60,$03,$05,$19,$19,$19,$19,$05,$03 ' Cust Char #4: speaker
LCDOUT $FE,$68,$00,$00,$04,$0E,$0E,$0E,$0E,$00 ' Cust Char #5: bullet
LCDOUT $FE,$70,$1F,$11,$11,$11,$11,$11,$11,$1F ' Cust Char #6: empty square
LCDOUT $FE,$78,$04,$0E,$1F,$0E,$0E,$00,$1F,$00 ' Cust Char #7: release
'blink led
for i = 0 to 10
HIGH PORTA.1
pause 300
LOW PORTA.1
PAUSE 300
NEXT i
'TEST block
'display a sample of the custom charas
LCDOUT $fe,1,"new charas: "
LCDOUT $fe,$c0,0,1,2,3,4,5,6,7
PAUSE 4000
LCDOUT $fe,1,"GPS display"
PAUSE 2000
gps:
LCDOUT $fe,1,"in GPS"
LCDOUT $fe,$c0,"Serin start"
PAUSE 2000
mystring[0]=0 'init first byte of the string
serin2 portA.0,188,3000,toto,[WAIT("$GPRMC"),STR mystring\65\13]
If mystring[0]<>0 then
LCDOUT $fe,1,"Data avail."
PAUSE 2000
LCDOUT $fe,1,"No data"
PAUSE 2000
eNDIF
goto gps
toto:
LCDOUT $fe,1,"timeout"
PAUSE 2000
GOTO gps
